I have tried again and again to resize and rearrange the columns in one of my kinetic dashboards. I use the Personalize Columns button to rearrange the column order. Then I manually resize the columns in the grid so they all fit. Then I click Save Layout. But nothing gets saved. When I close and reopen the dashboard, the columns aren’t in the right order, and they have all reverted back to the original widths.
Has anyone else battled with this? Is there a better approach I should take?
Thanks!
Nate
You need to merge your personalization with your layer. You can do that in app studio.
After you finish this, go to Menu Maintenance find the form you were working on and add the layer to the customization field.
But this will make everyone else has your personalized layout.
bump Is this still an issue for others? After building a new Kinetic dashboard, personalizations to column order are not saved, even after clicking “Save Layouts” on the grid.
