Hello everyone,
I’m seeing some odd behavior in a PreProcessing BPM on SalesOrder.MasterUpdate(). The BPM is intended to check the part on the sales order line and compare it to the Customer’s price list. I have added a UD field “MinimumOrderQty” to the PriceListParts table which is compared against the quantity of the sales order. If the quantity on the order is less than this “MinimumOrderQty” UD field, I display a form warning the user and giving them an opportunity to update the quantity. This is working exactly as intended when I update anything on the order line except OrderDtl.OrderQty.
When updating order quantity, SalesOrder.ChangeSellingQtyMaster gets called before MasterUpdate. I am wondering if this is somehow causing the new quantity grabbed from the BPM form to be overridden. However in the MasterUpdate calls following ChangeSellingQtyMaster, I can see the value I enter in the data form in the OrderDtl.OrderQty field. It just never writes that value to the database.
I have considered calling “Update” in Post-Processing and then refreshing the sales order entry screen, but this seems inefficient.
