Sales territory, Primary salesperson change, "push" down to cust
Hi Virginia . Try it in Pilot. The salesperson gets updated on the customer
master once you post.
Gerry
Virginia
Sent: Thursday, October 15, 2009 8:24 AM
Subject: [Vantage] Re: Sales territory, Primary salesperson change, "push"
down to customer records?
I agree, this would make sense, but when you click on the reassign button,
the window is labeled Reassign Opportunities/Quotes and your specific
options are to effect open Opportunities/Quotes and to reassign open tasks.
There is no mention of master customer files.
Virginia
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Gerry
Loranger" <gloranger@...> wrote:
> Isn't this the Reassign process on the Salespersons tab, in the Sales
> Territory screen?
> Gerry
Behalf Of
> Virginia
> Sent: Wednesday, October 14, 2009 4:29 PM
> Subject: [Vantage] Sales territory, Primary salesperson change, "push"
down
> Vantage 6.1 - In the CRM module, we have changed the primary salesperson
for
> a specific sales territory, in sales territory maintenance. When you look
at
> the customer recors, this change has not effected the customer records. Is
> there a utility I can run so that the customer records will reflect the
> change in the primary salesperson?
> Thanks,
> Virginia Joseph
> Director, IT & Strategic Initiatives
> Deep Hole Specialists
Vantage 6.1 - In the CRM module, we have changed the primary salesperson for a specific sales territory, in sales territory maintenance. When you look at the customer recors, this change has not effected the customer records. Is there a utility I can run so that the customer records will reflect the change in the primary salesperson?
Virginia Joseph
Territory screen?
Gerry
Virginia
Subject: [Vantage] Sales territory, Primary salesperson change, "push" down
Virginia Joseph
I agree, this would make sense, but when you click on the reassign button, the window is labeled Reassign Opportunities/Quotes and your specific options are to effect open Opportunities/Quotes and to reassign open tasks. There is no mention of master customer files.
Virginia
> Territory screen?
> Gerry
> Virginia
> Thanks,
> Virginia Joseph
