Sales order entry
Looking for a way to be able to change the line # on a sales order.
for example, when I create sales order and put line information always generate with line num 1 instead of that I want to create line 4 is that possible? I can manually enter line number?
Please advice
Nope.
Best you can do is create placeholder line items for 1, 2, 3… then add your line 4. Then delete lines 1, 2, 3. (or leave them there as placeholders w/ zero qty).
There is a slightly better option. Use the PO Line ref field:
thanks
