Craig
(Craig Rogers)
October 23, 2018, 2:09pm
1
How do you choose the bin you want to ship the child parts of a sales kit from?
Parent part number: PartX-100
has Rev with child parts of (100) PARTX
When the sales order line of PartX-100 gets shipped it wont let me pick what bin i want to ship PARTX from.
jkane
(John Kane)
October 23, 2018, 2:41pm
2
Sorry, but I have to start with a stupid question.
Is the Parent Part set as a Sales Kit in the part master?
jkane
(John Kane)
October 23, 2018, 2:48pm
4
Is there anything special about PartX? Non-stock, quantity bearing, serial tracked, lot tracked, etc.
jblomstedt
(Jeff Blomstedt)
October 23, 2018, 2:49pm
5
In Customer Shipment Entry, under the lines, there is a “Sales Kit Component Issue” Tab
Craig
(Craig Rogers)
October 23, 2018, 2:51pm
6
i checked there. Bin was grayed out
Craig
(Craig Rogers)
October 23, 2018, 2:52pm
7
Part is stock part, quantity bearing, not lot or serial tracked. inventory on hand. primary bins set up for both warehouses.
ckrusen
(Calvin Krusen)
October 23, 2018, 2:54pm
8
Does it not pull from the desired bin?
Or are you looking for how to change it if you had the part in multiple bins?
Craig
(Craig Rogers)
October 23, 2018, 2:55pm
9
Not pulling from the desired bin. i want it to pull from the primary bin on the child part. or at least let me pick the bin.
Craig
(Craig Rogers)
October 23, 2018, 2:56pm
10
it seems to be pulling from the site default shipping bin.
jkane
(John Kane)
October 23, 2018, 2:57pm
11
Is “Backflush Kit Components” set to True?
Craig
(Craig Rogers)
October 23, 2018, 2:58pm
12
yes. it was. i tool it off then tested it again. and still didnt let me pick the bin.
jkane
(John Kane)
October 23, 2018, 2:59pm
13
You are going to have to check that field everywhere. Part Site, Part, Site, Company…
ckrusen
(Calvin Krusen)
14
Are you looking at tge bin for tge parent part (which doesnt really exist) or tge bin the component actually gets pulled from?
What does part Tran history say for the component part?
Craig
(Craig Rogers)
October 23, 2018, 3:01pm
15
component part shows a STK-KIT transaction pulling from the bin i dont want it to.
ckrusen
(Calvin Krusen)
October 23, 2018, 3:07pm
16
Just one component doesn’t pull right, and other components of the same kit do?
Does the parent part have a primary bin assigned?
Craig
(Craig Rogers)
October 23, 2018, 3:10pm
17
its only 1 part in the BOM. 100 of PARTX
yes i put a primary bin on the parent part too.
jkane
(John Kane)
October 23, 2018, 3:11pm
18
There are multiple places where the Sales Kit options are. Have you checked them all to make sure that they don’t have the Backflush checked?
***********************************************************************************************************************************Ignore, my bad. I could only find the settings on Part. I must have been thinking of Lots. Sorry.
jkane
(John Kane)
October 23, 2018, 3:24pm
19
The setting is saved when the order is entered. Is the “Sales Kit Params” active on the order line? If not, you will have to delete the line and reenter it to take the new parameters.
Or, you can create a new order with the part that you took the backflush off and it will work.
