Sales Kit on PO
I have no idea what is going on. I have a part num I can’t add to a PO because it says “Sales Kits are not allowed on PO”. In a DB that is a few weeks older I can add it fine. I have checked the part in both DB and can’t find a difference. What else can I check?
Thanks Kim
I found the issue. They had the Type set as sales kit under the part plant record. Thanks
What is the part type in the DB that does not work? DJD
They has it set to Sales Kit
