I would sometimes see this if there was still a version of Epicor/Kinetic still running as an orphan. Rebooting makes sure those zombies are dead but careful use of the Task Manager has also worked.
I can’t get in either. Just booted up the computer from a long weekend, so I don’t think there should be any remainders of a previous instance. I tried clearing the cache folder too.
First Feature that I checked was the elimination of Periodic Posting Process.
For those that are familiar with this - Epicor has taken a unique approach on the solution.
It will be easy to move from version to version in the future and even into 10.2.500? if someone want to have this now.
The detail is similar to what I have done in the past.
Here’s the STK-CUS script. Else If COSAndWIP–PartTran–Details–Tran Type = ‘STK-CUS’
Result= Concatenate Result + ’ Order:’ + COSAndWIP–PartTran–Sales Order Detail–Order Num + ‘/’ + COSAndWIP–PartTran–Sales Order Detail–Line Num + ‘/’ + COSAndWIP–PartTran–Sales Order Detail–Release Num + ’ Pack:’ + COSAndWIP–PartTran–Shipping Details–Slip Num + ‘/’ + COSAndWIP–PartTran–Shipping Details–Line Num + ’ Cust:’ + COSAndWIP–PartTran–Customer–Customer ID*
I knew .NET 6.0 for the server, but is that now true for the client? I didn’t think they were going to invest in that upgrade since the client is going away.
I tried it again a few minutes ago. It then updated instead of the error message. However, after the update when I double click the icon nothing happens.
And I believe Olga mentioning that if you’re doing server-side development (Directives, etc.) then you’ll need .Net 6 at the client. But I think the client itself is still 4.8 Framework and not Core.
I don’t have any information on the initial error being reported here. But I do want to add some clarity as there seems to be some confusion with the platform.
.NET 6 was introduced in 2022.1 (server only). There are no major platform changes in 2022.2 so the server remains on .NET 6 and the client remains on .NET Framework 4.8.
Developing custom code (method directives, etc.) does not require .NET 6 on the client. If it is installed, it will take advantage of it for code validation. But if it not installed, it will gracefully fall back to using .NET Framework 4.8.
In Kinetic - searching for PO Suggestions - you need to scroll down to bring in all of the records.
After you have them all and select all - still not allowing you to bring in all of the records you want to review.
Only the first 200
To my knowledge Epicor Auto-Update was never good at updating the Client for Major Versions. You may need to make sure you re-download the latest 11.2.200 Client.
I am making an assumption you relied on Auto-Update, perhaps you didnt.
Also I run Epicor.exe and not Kinetic.exe for success.
