If you turn on Tracing and then process an Inspection Processing record, that will list all of the business object methods that were called as you did them. When parts are inspected in Inspection Processing, the InspProcessing business object is called and the methods used are InspectABC where ABC is either FirstArticles, Inventory, Materials, Operations, or Receipts depending on the type of nonconformance being inspected.
