We have a customized Time Phase screen. I have added custom columns to the time phase dataview and they work as intended. I was tasked to cause a row in the grid to turn a color to indicate if the sales order displayed in the dataview matched certain conditions. I added a row rule on the dataview column and it indeed causes the row to change color. Now if another part number is called up, the row in the grid does not “un-color” - once set it does not reset. closing the form and re-opening works as expected until another part is encountered that matches the rule then that row stays colored in the grid
anyone have any ideas on how to make this work as desired?
Interesting observation - if the subsequent part is looked up using the part search button, the colored row resets vs. typing the part number directly …
EDIT - A little to optimistic - still does it regardless of method of entering part number
