Row has been modified error - but not on save
I have an employee who jsut created a new part. However, whenever the part is opened on the part entry screen, I get this error:
Row has been modified by another user and couldn't be updated.
Error Detail
Description:  Row has been modified by another user and couldn't be updated.
Program:  Epicor.Ice.dll
Method:  Validate
Line Number:  106
Column Number:  21
Table:  PartPlant
Field:  SysRevID
Server Trace Stack:     at Ice.Core.BizRuleEngine.Validate(IceRow oldRow, IceRow newRow, LinqRow curRow) in D:\_Releases\ICE\3.1.500.46\Source\Framework\Epicor.Ice\BizRuleEngine\BizRuleEngine.cs:line 106
   at Ice.Services.Trace.TablesetProfilingCollector.DoRowEventTrace(String tableName, String methodName, Int32 rowCount, Action action) in D:\_Releases\ICE\3.1.500.46\Source\Framework\Epicor.Ice\Services\TablesetProfilingCollector.cs:line 146
   at Ice.TablesetBound`3.UpdateRow(IceDataContext dataContext, Int32 tableNum, IIceTable table, IceRow updatedRow, IceRow originalRow, TablesetProfilingCollector parentTraceCollector) in D:\_Releases\ICE\3.1.500.46\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1149
   at Ice.TablesetBound`3.WriteTable(IceDataContext dataContext, Int32 tableIndex, IIceTable table, TablesetProfilingCollector parentTraceCollector) in D:\_Releases\ICE\3.1.500.46\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 895
   at Ice.TablesetBound`3.InnerUpdate(IceDataContext dataContext, TFullTableset tableset) in D:\_Releases\ICE\3.1.500.46\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 797
   at Erp.Services.BO.PartSvc.Update(PartTableset& ds) in C:\_Releases\ERP\UD10.1.500.46\Source\Server\Services\BO\Part\Part.Designer.cs:line 5583
   at Epicor.Customization.Bpm.MethodCustomizationBase2`3.RunDirectives(TParam parameters) in c:\_Releases\ICE\3.1.500\Current\Source\Server\Internal\Lib\Epicor.Customization.Bpm\MethodCustomizationBase2.cs:line 218
   at Epicor.Customization.Bpm.CustomizationBase2`3.Execute(TParam parameters) in c:\_Releases\ICE\3.1.500\Current\Source\Server\Internal\Lib\Epicor.Customization.Bpm\CustomizationBase2.cs:line 77
   at Epicor.Customization.Bpm.BO9B5EB4CBB8A14CF88C6609AB84796E44.PartSvcCustomization.Update(PartTableset& ds)
   at Erp.Services.BO.PartSvcFacade.Update(PartTableset& ds) in C:\_Releases\ERP\UD10.1.500.46\Source\Server\Services\BO\Part\PartSvcFacade.cs:line 2073
   at SyncInvokeUpdate(Object , Object[] , Object[] )
   at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
   at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func`2 func) in D:\_Releases\ICE\3.1.500.46\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
   at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in D:\_Releases\ICE\3.1.500.46\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
   at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in D:\_Releases\ICE\3.1.500.46\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
   at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
   at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
   at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
   at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
   at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
   at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
   at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
   at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
   at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
   at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
   at System.ServiceModel.Channels.SecurityChannelListener`1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
   at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
   at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
   at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
   at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
   at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
   at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
   at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
   at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
   at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
   at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
   at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
   at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
   at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
   at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
   at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
   at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
   at Erp.Proxy.BO.PartImpl.Update(PartDataSet ds)
   at Erp.Adapters.PartAdapter.OnUpdate()
   at Ice.Lib.Framework.EpiBaseAdapter.Update()
   at Erp.UI.App.PartEntry.PartTransaction.AdapterUpdate()
   at Erp.UI.App.PartEntry.PartTransaction.UpdateX()
I get the same error if I try to refresh the screen. At first I thought it was a customization error, but if I load part entry with only the base(no) customization, I still get the error. The error is not pointing at a method directive or data directive that I can tell, but lost as far as where to go from here and hoping someone else has an idea.
Still not 100% certain what happened to cause this. The employee says they were switching between two part records and that’s when / how it started. Either way, I made a UBAQ and marked the part inactive. Saved it. Then was able to reopen the part in part entry and reactivate and do anything else I wanted. Apparently I just needed to make a change through the UBAQ to get it all to work again.
