We have a part stuck in inspection, and it appears to be an RMA. In asking the RMA to clean it up they said they don’t know how as we don’t normally put RMAs through inspection. In trying to figure out why the part is in inspection I took a look at the Part Class and Inspection Required is not checked. Is there a way to understand why a part is in inspection?
In asking the production team for help to get the RMA out of inspection, they said they don’t know how as they normally only inspect POs and the process doesn’t work for RMAs… Any pointers / documentation we can reference on how to get an RMA through inspection?
By default all RMA receipts go into Inspection, it doesn’t matter if the Part Class is set to Inspect or not.
Like @Asz0ka suggested, here are the steps:
open up Inspection Processing
Select the RMA from the Tree view, this will open the RMA tab
In the lower left corner there is a Disposition button, click on it and the selected RMA will open in Disposition Entry
Click on the New icon, this will open the Disposition tab, here you can select how you would like to disposition the parts you rec’d on the RMA. Once you set everything the way you like, save the Disposition record.
@tpynepeak
The workflow you are looking for is not standard since any inventory that leaves the warehouse should be inspected to ensure only quality products are allowed back into inventory.
However, you should be able to use a BPM that whenever an RMA type of inspection record is created, you could then automatically set the required fields for the inspection (inspector, Pass Qty, Whse & Bin).
Trying to solve another issue related. The inventory is stuck in inspection.
We’re renaming bins. I created the new ones and moved the inventory. I have about 20 bins left. I cannot mark those bins inactive because epicor says I have “Bin has quantity in RMA inspection location.”
I figured out the part that is on an RMA in that bin. I then checked if it had a disposition. It does and appears to be correct. The RMA is closed. Unsure what else to do. Yet the inventory is stuck in RMA location and I cannot mark the bin inactive.
