Is it possible to allocate RMA to different accounts based upon the source of the RMA?
If so, it would be via GL Controls. Check the Tech Ref guides
The “Inventory Transaction Hierarchy” guide shows how the GL accounts are determined for many RMA related trans
Thanks, Calvin. It seems strange that you would not be allowed to designate this at the RMA level.
GL Control Codes can also be tied to Reason Codes, which are set at the RMA Line level.
Thanks Ernie, that is a good point to address the issue we have.
