Question for the group,
I need to setup a process for reworking serial tracked finished goods.
I have some ideas involving customizations and utilizing a UD table, but I’d love to hear some other ideas.
We produce units that are serial tracked, with internal components that are also serial tracked.
If a unit fails in the field, we bring it in and can change out internal components(serial tracked).
When the unit goes back to the customer, it should have the same part and serial number.
This finished part must also be updated with the correct serial matching, showing at any point in time all of the internal component serial numbers.
It is also possible that this unit will come back again for rework.
All ideas welcome!
Scott KaufmanBusiness Systems Analyst
Wi-Tronix
Are you using the RMA process to handle the return?
Currently we are not using the RMAs in Epicor. It is a very manual process today.
Units will come back years after the original order, so we need a new order and we will charge the customer for the repair/upgrade. This is why I was leaning more towards "Rework".
On Tue, Aug 19, 2014 at 7:33 PM, paul.morgan@... [vantage] <vantage@yahoogroups.com> wrote:
Â<div> <p><br>Are you using the RMA process to handle the return?</p> </div> <div style="color:#fff;min-height:0;"></div>
Hi Scott,
We create a new sales order (ie dont use the orginal sales order) for similar reason to you. Depending on the situation we will either disposition the RMA to a job (we manual create what we call a repair job - R00 then the RMA number so we have a visual link) or to stock.
Receipting the RMA will bring the serial number back into your system, but I am not sure of the internal serial number...... we only track the top level part.
cheers
Paul
