When you approve a revision you have to type in a reason, that is great. From most windows, when you finish typing, you tab once to get to “ok”. In Part Maintenance when you tab once from the text box, you end up on “Cancel”. I managed to customize the window to change the tab order, but I can’t find that window in Menu Maintenance to apply the customization. Does anyone know where this window is?
The Form Name is App.PartEntry.RevisionCheckInForm
