Returned Material Value (V5.1)
Even if the user remembers to key in the cost fields, entering 4 fields with
up to 4 decimal places is impossible to do repeatedly and accurately. This
is definitely a software problem not a procedural problem.
Patrick Winter
Sent: Tuesday, June 24, 2003 3:06 PM
Subject: RE: [Vantage] Returned Material Value (V5.1)
OK this is one thing I have been complaining about to Epicor. You are
supposed to tie the part to the original Sales Order which retains the
costing information. Our problem is that we ship a machine and the customer
want to return a piece of the machine (one part) back to us for credit (or
replacement). Since there is nothing to tie it to, it defaults to $0 and
the cost buckets have to be manually filled in (if the operator remembers).
I have been asking to default to the part master costs instead of $0. I
have been blown off numerous times on this issue.
Dan Tisone
Operations / IT Consultant
dan.tisone@...
(949) 440-3685 x148
Sent: Tuesday, June 24, 2003 12:55 PM
To: Vantage (vantage@yahoogroups.com)
Subject: [Vantage] Returned Material Value (V5.1)
When you process a RMA in Vantage and the returned part ends up in
inventory, how do you apply a cost to the transaction? When you process the
receipt back into inventory, the part goes in at zero cost. Unless this
transaction is manually processed via a cost adjustment, it will cause an
understated inventory value. I would be interested in how the rest of you
are handling this.
thanks,
inventory,
how do you apply a cost to the transaction? When you process the receipt
back
into inventory, the part goes in at zero cost. Unless this transaction is
manually
processed via a cost adjustment, it will cause an understated inventory
value.
I would be interested in how the rest of you are handling this.
thanks,
customer want to return a piece of the machine (one part) back to us for
credit (or replacement). Since there is nothing to tie it to, it
defaults to $0 and the cost buckets have to be manually filled in (if
the operator remembers). I have been asking to default to the part
master costs instead of $0. I have been blown off numerous times on
this issue.
Dan Tisone
dan.tisone@...
(949) 440-3685 x148
the receipt back into inventory, the part goes in at zero cost. Unless
this transaction is manually processed via a cost adjustment, it will
cause an understated inventory value. I would be interested in how the
thanks,
Epicor sent this to me the other day. Hopes this helps
Jasper
882MPS
What is the process flow for an RMA (Return Material Authorization) ?
PROBLEM RESOLUTION:
1. Select RMA Processing from the Accounts Receivable, Order Management or
Shipping/Receiving general operations folder.
2. Add the RMA Header record identifying the return number, date and
customer.
3. Add the RMA Detail Line record identifying the part, return quantity,
sales order reference and reason for return.
4. Add the RMA Receipt details recording the part receipts and where the
part resides.
A. RMA automatically moves to Inspection
B. Creates an RMA-INS transaction with zero cost
C. No GL entries are made
5. Add the RMA Credit Request indicating the quantity and unit price.
A. Credit Memo is automatically created.
B. Credit Memo is available for posting in Accounts Receivable
Invoice Entry Get RMA Credits
DEBIT 1) Returns Account from the part's Product Group
2) Returns Account from the AR Account assigned to the
customer
3) Returns Account from the default AR Account
4) Returns Account from the Control Account
CREDIT 1) Receivable Account from the AR Account assigned to the
customer
2) Receivable Account from the default AR Account
3) Receivable Account from the AR Configuration
6. Select RMA Dispositions from the Order Management general operation
folder or from the Quality general operation folder selecting inspection
processing.
7. Select an RMA record and indicate the quantity to be placed back in
stock, forwarded to a job, or falied / rejected outright, a writeoff. Unit
costs may be updated, defaults are calculated as follows: (If Failed /
rejected, see page 1989MPS, this now also creates a DMR record to be
processed in DMR Processing).
A. The cost of returns is captured during the actual receipt
process. Per Vantage
Help it is calculated in the following way:
· The first attempt to determine the cost is to retrieve the last
"costed" shipment that is related to the
associated order line.
· If no such order line exists, the cost comes from the last
shipment
for this part for this customer.
· If the last shipment is from manufacturing, but it isn't costed,
then
the cost is determined using the Capture COS logic----see Page
687MPS.
B. One of the following transactions and GL transactions are
created:
INS-MTL RMA receipt of job material
DEBIT 1) WlP Material from job's Product Group
2) WIP Material from Control Accounts
CREDIT 1) Cost of Returns account from part's Product
Group
2) Control Account's Cost of Returns account
INS-REJ Rejecting an RMA receipt
DEBIT 1) DMR reason code account
2) Part Class DMR Write Off account
3) Control Account's DM Write Off account
CREDIT 1) Product Group Cost of Returns account
INS-STK RMA receipt to stock
DEBIT 1) Account set up on Part
2) Part Class Inventory account
3) Control Account's Inventory account
Product Group
account
Page ID 1989MPS
RMA Processing within Quality Assurance
Disposition of RMA Pieces without the QA module will be done from the menu
option in Order Management. If QA is installed the processing for RMA
failed (use to be rejected) will follow DMR processing.
Pass INS-STK
Pieces accepted from QA to stock will update the on hand quantity as pre 5.1
Pass INS-MTL
Pieces can be received to a job material line as they are today. This
enables the QA person to effectively put nonpart master parts back to the
job they came from. This transaction will create a material on the job and
issue the parts to that material line. While this option could be used to
rework parts, Vantage Recommends that rework parts be processed through DMR
to enable logging the non-conformance, entering cause and corrective action
and consistent QA analysis through DMR reason codes.
Fail INS-REJ
Non-conformance record created automatically
Check box to bring the user to cause and corrective action
DMR Created automatically consistent with other non-conformance
Transaction will use DMR reason codes with inventory criteria
Failed pieces will go to DMR following the QA process like any other
purchase receipt or non-conformance item failing inspection.
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=249982.3179269.4495679.1261774/D=egroupweb/S=1705007183:HM/A=1524963/R=0/SIG=12ongbbsq/*http://hits.411web.com/cgi-bin/autoredir?camp=556&lineid=3179269&prop=egroupweb&pos=HM>
<http://us.adserver.yahoo.com/l?M=249982.3179269.4495679.1261774/D=egroupmail/S=:HM/A=1524963/rand=868898764>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
