Retrieve data from the Inspection Processing Window from the Print Window
Hello,
I’m trying to figure out if there is a way to get data from Inspection Processing Window from the Print Window?
I actually tried with the BPMContext but since this is not the same window, the BPMContext lose the data.
I’m trying to get this data:
Summary
			edvCallContextBpmData.dataView[edvCallContextBpmData.Row]["ShortChar01"] = edvmtlView.dataView[edvmtlView.Row]["PassedIssueTo"];
I know that I can use the UD table but I would like to test other thing before doing that.
For exemple, is there a way to send a report param from Inspection Processing?
Alexandre
