Retitled: 5.2 to 6.0 or 6.1
Great! Thank you!
Todd Caughey
Sent: Friday, January 20, 2006 4:24 PM
Subject: RE: [Vantage] Retitled: 5.2 to 6.0 or 6.1
For me 6.0 to 6.1 was virtually nothing and if you are already doing 5.2 to
6.0 it would be even less additional work because many of the "after" steps
(like reinstalling clients) would be a wash.
Julie Lehmann at Mercury Minnesota had sent me some very handy tips that
helped me greatly (my comments in() ):
A) The Progress Patch to 91D08 can be installed well in advance and works
with 6.0.
(Note: in your case just patch all the way to 91D08 when you isntall
9.1D - so essentially no extra time)
B) 6.1 can be installed on server in advance as well (a good point at
which to set DB settings too)
(I installed 6.1 to the MFGSYS61 folder several days in advance of
the cutover)
C) Then just procopy the DB, repoint the users to 61 and 1st time log-in
fire up the change schema and conversions
(basically just moving the DB to the mfgsys61/db folder - a few
minutes?)
So the "added time" for 6.1....a few minutes.
Added benefit...being on the "latest" pre-8 version and the only one Epicor
really wants to support (or has everyone familiar with) really helps.
Unless you are using CRM there would be little or no user impact except for
some odd and easily fixed font issues that affect some screens as related in
a post-6.1 posting I made:
The new DB was missing all my optimizations. Duh! Should have thought
about that. Main problem is -n parameter issue for number of users is less
than our licensed number. I should have matched all the DB settings from
mfgsys60 to mfgsys61. Something not mentioned in the install guide. I had
to set them and shutdown/restart DB at lunchtime the day after the switch -
if I had copied them down and entered them all would have been well.
The new fonts are horrible. You can reset them in one of the ini files
rightafter the upgrade.
Even if going just to 6.0 double check your backup routines for proper
paths.
Crystal reports will need to have location repointed to mfgwrk61 on the
client and database analyzed then save each report. Caution...save any
customized reports in a safe location for moving to new Userfiles folder
(after 1st preserving native 6.0 or 6.1 versions, just incase).
But really, there is very little extra work to go all the way to 6.1 and
lots to gain.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Rebecca Schmuck
Sent: Friday, January 20, 2006 3:39 PM
Subject: RE: [Vantage] Off-Topic: Quality Manager position available in
Richmond KY
Thanks for the input! I really would like to, but I'm not sure how much
longer that will take, and we are kind of server critical at this point!
Any idea on how long the conversion took from 6.0 to 6.1?
Edward F. Fox, Jr.
Sent: Thursday, January 19, 2006 3:55 PM
Richmond KY
Sorry this is not related to the job listing, but I recommend you consider
jumping right to 6.1.
Edward F. Fox, Jr. CPA
Controller
Maxson Automatic Machinery Company
Phone 401-596-0162 * Fax 401-596-1050
www.maxsonautomatic.com
Rebecca Schmuck
Sent: Thursday, January 19, 2006 4:23 PM
Cc: 'David C. Anderson (E-mail)'
Subject: [Vantage] Off-Topic: Quality Manager position available in Richmond
KY
We are a Metal Stamper seeking a full-time Quality Manager for our Richmond,
Kentucky location. We are currently running Vantage 5.2, but will be
migrating to 6.0 next week.
If you are interested in the following position, please contact Dave
Anderson at 773-235-4736 x242 or email him at danderson@...
Required Education: High School
Required Experience: At least 1 year
Required Travel: Negligible
Relocation Covered: No
QUALITY MANAGER
QUALITY MANAGER JOB DESCRIPTION:
* Develops,improves and implements Quality systems
* Supervises the testing and inspection of products at various stages
of production and compiles and evaluates statistical data to improve and
maintain quality and reliability of products
* Primary contact with customers on all Quality matters.
* Must have experience with automotive quality requirements and TS
16949 requirements.
QUALITY MANAGER ESSENTIAL JOB FUNCTIONS:
* Handles Quality inquiries from customers.
* Requests process change approval from customers.
* Performs PPAP procedure:
Quality Plan
R & R
Flow Charts
Packaging Plan
Work Instructions
PFMEA
Balloon Print
Dimensional Report
Bar Code Label
Material Certs
Process Capability Study
* Champion Work Improvement groups.
* Conduct Design of Experiments.
* Insures that Quality procedures are understood and in place at
workstations.
* Provides training and guidance to operators, set-up personnel and
night shift Quality personnel on Quality and process applications and other
items needing special attention.
* Develops and provides necessary Quality documents to Production
personnel and maintains files (Prints, Quality Plans, PFMEA, Forms, etc.)
* Writes Quality procedures.
* Notifies the Quality Manager of Quality issues and makes
recommendations on possible improvements.
* Reads and interprets engineering drawings, schematic diagrams, and
Quality plans.
* Tests products for variety of qualities, such as dimensions,
performance, or finish, using micrometers, vernier calipers, height and
depth gauges, fixtures and optical comparator.
* Calibrates metrology equipment and maintains calibration records.
* Records test data, applying statistical process control procedures.
* Evaluates SPC data and writes reports to validate or indicate
deviations from existing standards.
* Performs in-process inspection and tests on materials or parts to
measure performance or material characteristics, including CMM and other
metrological devices.
* Prepares graphs or charts of data for analysis.
* Shows machine operators how to measure and test parts.
* Conducts and coordinates Internal Quality Audits and Vendor Audits.
* Coordinates with customers to resolve Quality issues.
* Drafts and champions Corrective Action Reports (CAR).
* Develops Cost of Quality data.
OUR COMPREHENSIVE BENEFITS PACKAGE INCLUDES:
* Medical
* Paid Vacation & Holidays
* 401k with Profit Sharing
REQUIREMENTS
QUALITY MANAGER JOB REQUIREMENTS:
* PC-literate (Wordprocessing/Spreadsheet/Quality applications)
* SPC mastery
* Skilled on all manual metrology devices (Advanced Metrology)
* Skilled in operation of the comparator
* Advanced blue print reading
* Training Techniques
Yahoo! Groups Links
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage>
" on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
_____
Yahoo! Groups Links
For me 6.0 to 6.1 was virtually nothing and if you are already doing 5.2 to 6.0 it would be even less additional work because many of the "after" steps (like reinstalling clients) would be a wash.
Julie Lehmann at Mercury Minnesota had sent me some very handy tips that helped me greatly (my comments in() ):
A) The Progress Patch to 91D08 can be installed well in advance and works with 6.0.
(Note: in your case just patch all the way to 91D08 when you isntall 9.1D - so essentially no extra time)
B) 6.1 can be installed on server in advance as well (a good point at which to set DB settings too)
(I installed 6.1 to the MFGSYS61 folder several days in advance of the cutover)
C) Then just procopy the DB, repoint the users to 61 and 1st time log-in fire up the change schema and conversions
(basically just moving the DB to the mfgsys61/db folder - a few minutes?)
Added benefit...being on the "latest" pre-8 version and the only one Epicor really wants to support (or has everyone familiar with) really helps. Unless you are using CRM there would be little or no user impact except for some odd and easily fixed font issues that affect some screens as related in a post-6.1 posting I made:
The new DB was missing all my optimizations. Duh! Should have thought about that. Main problem is -n parameter issue for number of users is less than our licensed number. I should have matched all the DB settings from mfgsys60 to mfgsys61. Something not mentioned in the install guide. I had to set them and shutdown/restart DB at lunchtime the day after the switch - if I had copied them down and entered them all would have been well.
The new fonts are horrible. You can reset them in one of the ini files rightafter the upgrade.
Even if going just to 6.0 double check your backup routines for proper paths.
Crystal reports will need to have location repointed to mfgwrk61 on the client and database analyzed then save each report. Caution...save any customized reports in a safe location for moving to new Userfiles folder (after 1st preserving native 6.0 or 6.1 versions, just incase).
But really, there is very little extra work to go all the way to 6.1 and lots to gain.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Rebecca Schmuck
Subject: RE: [Vantage] Off-Topic: Quality Manager position available in Richmond KY
Edward F. Fox, Jr.
Richmond KY
Controller
Rebecca Schmuck
KY
QUALITY MANAGER
16949 requirements.
Quality Plan
R & R
Flow Charts
Packaging Plan
Work Instructions
PFMEA
Balloon Print
Dimensional Report
Bar Code Label
Material Certs
workstations.
Quality plans.
* Medical
REQUIREMENTS
* SPC mastery
Yahoo! Groups Links
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
