Retail Sales - Multiple Warehouses
So how do we select which warehouse/bin to pull from on the sales order? The only location that I can see is on the release tab.
It would be nice if each user could define a primary warehouse that they will be pulling stock from but I can't see where this would be done.
--- In vantage@yahoogroups.com, Mark Wagner <mjfw2003@...> wrote:
> Lots of questions here in order to help you, but you do not to create separate releases to pull from separare warehouses. When you go to ship, if your parts are make to stock, your shipment person can dicate where the parts are shipping from (select warehouse and bin) If you are not multi-company and are just setting default warehouses, then your shipment entry lines will default to the primary warehouse but you can always change those when you ship. Are you expecting the same part to default to different warehouses when shipping?
> --- On Sat, 8/28/10, johngeh <johngeh@...> wrote:
> From: johngeh <johngeh@...>
> Subject: [Vantage] Retail Sales - Multiple Warehouses
> To: vantage@yahoogroups.com
> Date: Saturday, August 28, 2010, 7:00 PM
> ÂÂ
> We are using Epicor to sell product in a steel service center.
> We expanded and started a second location.
> We have figured out how to create a new warehouse and configure the parts to allow them to be located in multiple warehouses.
> The problem is when we go to create a sales order. It appears that we need to create a release for each line to pull from anything other than the primary warehouse.
> There must be an easier way to do this.
> Has anyone else out there had to do this?
> Any suggestions?
Any suggestions?
Â
Any suggestions?
