In a BAQ you can set a parameter to be a "LIST as such
In the oData SWAGER Helper It shows up as a “list” multiple values supported
However I can’t fingure out the syntax of the list items. I tried
AAA,BBB
'AAA','BBB'
'AAA,BBB'
AAA~BBB //Cheeky Jab
AAA and BBB
AAA or BBB
And nothing works, if I pass only 1 item. It works fine, more than one returns no results.
Any ideas?
@Olga @Bart_Elia
Did you try:
‘ABC’ or ‘BBB’
‘AAA’ and ‘BBB’
in RESTful it would look like:
yourepicorsite.com/_api/web/Lists/getbyCustomer(‘Customer’)/items?$filter=((Customer eq ‘AAA’) or ‘BBB’))
How about using brackets?
(‘AAA’) or (‘BBB’)
Or even:
Customer eq ‘AAA’ or customer eq ‘BBB’
Well is not a filter, these are params. As filters it would work but I specifically need the List Params to work.
Is it not just something like this? The BAQ does only get called once when this is passed which tells me it is filling the list param. In my example JobNum is setup as my list param
https://SERVER/DEMO600/api/v1/BaqSvc/Jobs?JobNum=2413&JobNum=2022
Olga
(Olga Klimova)
9
yes, i think you are right.
I have note that “Value list parameters may be specified several times.”
It is not possible in Help page though
I’ll give it a shot, thanks @danbedwards
Worked like a charm! Thanks!
MontyMan
(Monty Wilson)
12
Jose, would you mind giving a brief example of the syntax that worked? I clicked Dan’s link and got a “site not available” error. Thanks!
I think the link from @danbedwards was actually an example of the syntax you want, so in this case
…{yourServer}/{yourAppServer}/api/v1/BaqSvc/Jobs?JobNum=2413&JobNum=2022&JobNum=4560…etc
The syntax that he provided worked as advertised @MontyMan
