Ahhh the great misunderstanding between authentication and licensing. I think I have a few dozen posts on this running around and assume I should write up an Experts Thesis once and for allâŚ
First - Donât confuse a Session and a License âClaimâ.
They are two separate entities and concepts with only a single aspect crossing over between themâŚ
A License Claim is someone reserving a particular license with a set timeout. Whatâs the timeout? Whatever is set for the User:
As long as the user connects to the server in under 480 minutes in this case, it continues its claim. It resets the claim forward another 480 minutes or whatever the setting.
So the next question is always, how do I make a claim?
When the server is called, a claim is made immediately as a part of the service call instance - GetList, GetRows, ChangeThis, etc. A license is checked for and claimed for the life of the server call. At the end of the call, poof the claim goes away and license returned to the pool after the 1 ms for a fast call or 4 hours for an MRP run. Without other factors, the single call is the life of the license claim.
But I make a bunch of calls in a users process if someone uses up licenses, I get an out of license error!(Entering a sales order makes more than a single server call obviously)
Thatâs where Session comes into play.
When you make the first call to the server, call SessionModSvc.Login(). It will return you a SessionID and the server will start persisting the Session State for 72 hours of non access or until the client calls âSessionModSvcLogOutâ.
Urban legend is that 72 hours is to cover someone partially entering data on Friday and leaving work without saving so they can click âSaveâ on Monday morning and continue like there was no time gap. This pattern is from the mid 90s in Vantage ⌠4? Earlier? So predates my involvement with the code base
FYI - The Login / Logout can be done for you automatically if you use the clientâs Ice.Core.Session object and use that Session with Client Impl classes.
The SessionID will need to be passed to the server on every call. Itâs a part of the Call Headers and has been discussed in other threads before. It allows a client to have faith in holding a license claim between calls among other needs. As long as you show up with a SessionID holding a License Claim under the time limits, you are good to go ⌠well forever. Youâll never get the dreaded âout of licensesâ error.
If you just want to call the server with no session for a fast query, go ahead - just remember to deal with out of license issues on your own
I hope that helps?
