Rest api
Hello,
question on REST API. if we use cloud Kinetic version, the rest api is on public or we need go through epicor vpn to access REST API.
thanks,
Eddy
If you don’t need a VPN to connect with the client, you won’t need one for the REST API
You will need be able to go to the Swagger page same as on-premise.
e.g
https://serverName.epicorsaas.com/instanceName/api/help/v1/index.html
You can do your standard REST requests e.g GET, POST, PATCH as you would on-premise. The only downside is you do not get access to the server so you will need to do all of your debugging through Postman, DevTools (Chrome, Edge) etc.
No VPN needed, just your ERP creds and a API Key if you’re planning to use V2.
Hope this helps.
