I’ve had success using the new REST API, but I am running into a problem with the ChangeJobHeadJobEngineered custom method. What methods of debugging are available besides the REST return message and the AppServer error log? Does anyone have insight on calling this custom method?
I’m confident that the dataset (ds) parameter being passed is correct. It matches what I see from the dataset in a trace I captured and the swagger API example. When calling this custom method the API responds with the general error message.
Sorry! Something went wrong. Please contact your system administrator.
The AppServer error message is…
Business Logic Error
Business Layer Exception
BLException
Description: JobHead has not changed.
Program: Erp.Services.BO.JobEntry.dll
Method: ChangeJobHeadJobEngineered
Line Number: 9200
Column Number: 17
Table: JobHead
Server Trace Stack: at Erp.Services.BO.JobEntrySvc.ChangeJobHeadJobEngineered(JobEntryTableset& ds) in C:_Releases\ERP\UD10.1.500.15\Source\Server\Services\BO\JobEntry\JobEntry.cs:line 9200
at Erp.Services.BO.JobEntrySvcFacade.ChangeJobHeadJobEngineered(JobEntryTableset& ds) in C:_Releases\ERP\UD10.1.500.15\Source\Server\Services\BO\JobEntry\JobEntrySvcFacade.cs:line 565
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Ice.Hosting.RestApi.OperationInvokeHelper.<>c__DisplayClass25_0.b__0(Object obj) in C:_Releases\ICE\3.1.500.15\Source\Framework\Epicor.Ice\Hosting\ServiceCaller\OperationInvokeHelper.cs:line 285
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in C:\_Releases\ICE\3.1.500.15\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59 at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func
2 func) in C:_Releases\ICE\3.1.500.15\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
at Ice.Hosting.RestApi.OperationInvokeHelper.CallInvoker(IceDataContext dataContext, Type svcType, MethodInfo mi, Object[] inputs) in C:_Releases\ICE\3.1.500.15\Source\Framework\Epicor.Ice\Hosting\ServiceCaller\OperationInvokeHelper.cs:line 284
at Ice.Hosting.RestApi.OperationInvokeHelper.MakeServiceCall(IceDataContext dataContext, Type svcType, MethodInfo mi, Object[] parameters) in C:_Releases\ICE\3.1.500.15\Source\Framework\Epicor.Ice\Hosting\ServiceCaller\OperationInvokeHelper.cs:line 242
at Epicor.RESTApi.DataSources.IceServiceCaller.CallCustomMethod(TypeMapping typeMapping, ContextInfo context, String methodName, Object inputObject) in c:_Releases\ICE\3.1.500\Current\Source\Framework\Epicor.RESTApi\DataSources\IceServiceCaller.cs:line 244
at Epicor.RESTApi.Controllers.CustomActionController.CustomMethod(Object input) in c:_Releases\ICE\3.1.500\Current\Source\Framework\Epicor.RESTApi\Controllers\CustomActionController.cs:line 25
at lambda_method(Closure , Object , Object[] )
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.b__9(Object instance, Object[] methodParameters)
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary2 arguments, CancellationToken cancellationToken) at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext() at System.Runtime.CompilerServices.AsyncTaskMethodBuilder
1.Start[TStateMachine](TStateMachine& stateMachine)
at System.Web.Http.Controllers.ApiControllerActionInvoker.InvokeActionAsyncCore(HttpActionContext actionContext, CancellationToken cancellationToken)
at System.Web.Http.Controllers.ApiControllerActionInvoker.InvokeActionAsync(HttpActionContext actionContext, CancellationToken cancellationToken)
at System.Web.Http.Controllers.ActionFilterResult.b__0(ActionInvoker innerInvoker)
at System.Web.Http.Controllers.ActionFilterResult.<>c__DisplayClass101.<InvokeActionWithActionFilters>b__f() at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() at System.Runtime.CompilerServices.AsyncTaskMethodBuilder
at System.Web.Http.Filters.ActionFilterAttribute.CallOnActionExecutedAsync(HttpActionContext actionContext, CancellationToken cancellationToken, Func1 continuation) at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext() at System.Runtime.CompilerServices.AsyncTaskMethodBuilder
at System.Web.Http.Filters.ActionFilterAttribute.ExecuteActionFilterAsyncCore(HttpActionContext actionContext, CancellationToken cancellationToken, Func1 continuation) at System.Web.Http.Filters.ActionFilterAttribute.System.Web.Http.Filters.IActionFilter.ExecuteActionFilterAsync(HttpActionContext actionContext, CancellationToken cancellationToken, Func
1 continuation)
at System.Web.Http.Controllers.ActionFilterResult.d__2.MoveNext()
at System.Runtime.CompilerServices.AsyncTaskMethodBuilder1.Start[TStateMachine](TStateMachine& stateMachine) at System.Web.Http.Controllers.ActionFilterResult.ExecuteAsync(CancellationToken cancellationToken) at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext() at System.Runtime.CompilerServices.AsyncTaskMethodBuilder
at System.Web.Http.Filters.AuthorizationFilterAttribute.ExecuteAuthorizationFilterAsyncCore(HttpActionContext actionContext, CancellationToken cancellationToken, Func1 continuation) at System.Web.Http.Filters.AuthorizationFilterAttribute.System.Web.Http.Filters.IAuthorizationFilter.ExecuteAuthorizationFilterAsync(HttpActionContext actionContext, CancellationToken cancellationToken, Func
1 continuation)
at System.Web.Http.Controllers.AuthorizationFilterResult.ExecuteAsync(CancellationToken cancellationToken)
at System.Web.Http.ApiController.ExecuteAsync(HttpControllerContext controllerContext, CancellationToken cancellationToken)
at System.Web.Http.Dispatcher.HttpControllerDispatcher.d__1.MoveNext()
at System.Runtime.CompilerServices.AsyncTaskMethodBuilder1.Start[TStateMachine](TStateMachine& stateMachine) at System.Web.Http.Dispatcher.HttpControllerDispatcher.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.HttpMessageInvoker.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Web.Http.Dispatcher.HttpRoutingDispatcher.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.DelegatingHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Web.Http.HttpServer.<SendAsync>d__0.MoveNext() at System.Runtime.CompilerServices.AsyncTaskMethodBuilder
at System.Web.Http.HttpServer.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Web.Http.Owin.HttpMessageHandlerAdapter.d__0.MoveNext()
at System.Runtime.CompilerServices.AsyncTaskMethodBuilder.Start[TStateMachine](TStateMachine& stateMachine)
at System.Web.Http.Owin.HttpMessageHandlerAdapter.InvokeCore(IOwinContext context, IOwinRequest owinRequest, IOwinResponse owinResponse)
at Epicor.RESTApi.ConfigureStartup.<>c__DisplayClass3_0.b__0(IOwinContext context, Func1 next) in c:\_Releases\ICE\3.1.500\Current\Source\Framework\Epicor.RESTApi\Startup.cs:line 140 at Microsoft.Owin.Mapping.MapWhenMiddleware.<Invoke>d__0.MoveNext() at System.Runtime.CompilerServices.AsyncTaskMethodBuilder.Start[TStateMachine](TStateMachine& stateMachine) at Microsoft.Owin.Mapping.MapWhenMiddleware.Invoke(IDictionary
2 environment)
at Microsoft.Owin.Host.SystemWeb.IntegratedPipeline.IntegratedPipelineContextStage.d__5.MoveNext()
at Microsoft.Owin.Host.SystemWeb.IntegratedPipeline.IntegratedPipelineContextStage.RunApp(Func2 entryPoint, IDictionary
2 environment, TaskCompletionSource`1 tcs, StageAsyncResult result)
at Microsoft.Owin.Host.SystemWeb.IntegratedPipeline.IntegratedPipelineContextStage.BeginEvent(Object sender, EventArgs e, AsyncCallback cb, Object extradata)
at System.Web.HttpApplication.AsyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
at System.Web.HttpApplication.PipelineStepManager.ResumeSteps(Exception error)
at System.Web.HttpApplication.BeginProcessRequestNotification(HttpContext context, AsyncCallback cb)
at System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context)
at System.Web.Hosting.PipelineRuntime.ProcessRequestNotificationHelper(IntPtr rootedObjectsPointer, IntPtr nativeRequestContext, IntPtr moduleData, Int32 flags)
at System.Web.Hosting.PipelineRuntime.ProcessRequestNotification(IntPtr rootedObjectsPointer, IntPtr nativeRequestContext, IntPtr moduleData, Int32 flags)
at System.Web.Hosting.UnsafeIISMethods.MgdIndicateCompletion(IntPtr pHandler, RequestNotificationStatus& notificationStatus)
