Resource Burden Rate
This is the first time I want to make a resource burden rate different than the standard company burden rate. The box in the screen shot, does that override the overall burden rate or will it add to it?
IE:
Company burden rate is $85, new resource should be $140 total. Do I place the $140 or the difference of $55 in that field?
It overrides it. So, in your example, the $140.
Thank you so much!
