Require Ref Designators is too large for its format of '>>>>9'
Receiving this error message trying to enter a quantity/parent of 100,000 into a material used on a job. We do not use Reference Designators at all but this field seems to be limiting the quantity I can enter. Any suggestions, either to disable the use of Reference Designators completely or remove the field limitation?
Check the Extended properties for that Table and column and change the Format value with the increased limitation.
I was just opening extended properties when you responded… it worked! Thank you for the help!
