Request for basic Help
Thanks so much for the help. I truly appreciate everything. With a little patience I will get this.
Thanks again
Mark Trzaska
Administrator
Stanley Machining & Tool Corp.
425 Maple Avenue
Carpentersville, IL 60110
Phone (847) 426-4560
Fax (847) 426-6951
e-mail Mtrzaska@...<mailto:Mtrzaska@...>
Hi all,
For all you really smart people out there this is a simple question.
Im trying to set-up a BPM that when a needbydate on a Sales Order has changed an e-mail would go out displaying pertinent info. I think im to use a pre-processing then look for changes on the ordered,orderdtl,orderrel tables
But what is throwing me is do I use a condition that if the updated table Needbydate has changed from ? to ? then email. It's the condition that im unsure of. Or is it a custom code. Coding is, unfortunately, my weak point.
Thank
Mark Trzaska
Administrator
425 Maple Avenue
Fax (847) 426-6951
I believe a BAM not a BPM is the way to go with this, you can monitor that
field and have an email sent when it changes.
Trzaska, Mark
Sent: Wednesday, May 01, 2013 11:02 AM
Subject: [Vantage] Request for basic Help
Hi all,
tables But what is throwing me is do I use a condition that if the updated
point.
Thank
Mark Trzaska
Administrator
425 Maple Avenue
Fax (847) 426-6951
There is a BAM example I made for OrderRel in the file section under BAM folder.
The link below has the basics of how to add the .p procedure to a BAM. I used it when I first started using BAM custom emails.
http://f1.grp.yahoofs.com/v1/1FiBUdVcmahNmtCh_R3mI0-z03nhmnNlpxW3_qJoqwjPzw9qyT2xC1zZSNEotCef4lC5NDTo1fW_C_FZeX4Yp5aCjzcFiseBXMkCMwRDbpqr6hd9/BAM_Alert_OrderRel_DropShip.zip
If you use the release need by then you can reference the partnum, etc to make the email complete.
Let me know if you have any specific coding questions.
Greg Payne
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ned
Sent: Wednesday, May 01, 2013 1:19 PM
Subject: RE: [Vantage] Request for basic Help
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Trzaska, Mark
Hi all,
point.
Thank
Mark Trzaska
Administrator
425 Maple Avenue
Fax (847) 426-6951
e-mail Mtrzaska@...<mailto:Mtrzaska%40StanleyMachining.com><mailto:Mtrzaska@...<mailto:Mtrzaska%40StanleyMachining.com>>
http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
You can do it without code.
Only looked at it without trying it, but if you add a post process on the update of Sales Order. As the condition select "Method changed the specific field of the designed query from any to any". If you design the query - just add the table you want to check and select the field you wish to check. Leave the any to any as it is.
In the action section select send an email based on template.
Regards
Martin Horton
Business Systems Manager
Broadcrown Ltd
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Trzaska, Mark
Sent: 01 May 2013 16:02
Hi all,
Thank
Mark Trzaska
Administrator
425 Maple Avenue
Fax (847) 426-6951
Broadcrown Ltd. Airfield Industrial Estate, Hixon, Stafford, Staffs ST18 0PF, England
tel: +44(0)1889 272200 fax: +44(0)1889 272220 www.broadcrown.com
----- This email and the information it contains is confidential and may be legally privileged. It may be read, copied and used only by the intended recipient. Internet communications cannot be guaranteed to be secure or indeed error free as information can be intercepted, corrupted, lost, destroyed, delayed and or contain viruses. Broadcrown Ltd has scanned the email for viruses but does not accept responsibility once the email has been transmitted. The receiving company should scan the email and attachments (if any) for viruses. Any views or opinions expressed within this email are not necessarily the views or opinions of Broadcrown Limited except where the sender specifically states that they are. If you have received this document in error please email the sender and delete the message from your computer without taking copies -----
Does anybody have a BPM that notifies a changed date ? I know there is a field in order detail that shows when an order is changed. (OrderDtl.ChangeDate)
Sent from my iPhone
On May 1, 2013, at 6:13 PM, "Martin Horton" <mhorton@...<mailto:mhorton@...>> wrote:
Regards
Martin Horton
Broadcrown Ltd
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Trzaska, Mark
Hi all,
Thank
Mark Trzaska
Administrator
425 Maple Avenue
Fax (847) 426-6951
e-mail Mtrzaska@...<mailto:Mtrzaska%40StanleyMachining.com><mailto:Mtrzaska%40StanleyMachining.com<http://40StanleyMachining.com>><mailto:Mtrzaska@...<mailto:Mtrzaska%40StanleyMachining.com><mailto:Mtrzaska%40StanleyMachining.com<http://40StanleyMachining.com>>>
tel: +44(0)1889 272200 fax: +44(0)1889 272220 www.broadcrown.com<http://www.broadcrown.com>
Where on the server is the best or customary place to put these .p files?
Bob Beaghan
> Greg Payne
> Trzaska, Mark
> Hi all,
> point.
> Thank
> Mark Trzaska
> Administrator
> 425 Maple Avenue
> Fax (847) 426-6951
\\svr\Epicor905\Server\ud<file:///\\svr\Epicor905\Server\ud> or a sub directory is where the bam expects them. I have a dev sub directory to isolate changes to current BAMs.
It is explained in the zip file link.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of robertbeaghan
Sent: Thursday, May 02, 2013 9:41 AM
Subject: [Vantage] Re: Request for basic Help
Bob Beaghan
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Greg Payne <gpayne@...<mailto:gpayne@...>> wrote:
> Greg Payne
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Ned
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
> Trzaska, Mark
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Hi all,
> point.
> Thank
> Mark Trzaska
> Administrator
> 425 Maple Avenue
> Fax (847) 426-6951
> e-mail Mtrzaska@...<mailto:Mtrzaska%40StanleyMachining.com><mailto:Mtrzaska@...<mailto:Mtrzaska%40StanleyMachining.com<mailto:Mtrzaska@...%3cmailto:Mtrzaska%40StanleyMachining.com%3e%3cmailto:Mtrzaska@...%3cmailto:Mtrzaska%40StanleyMachining.com>>>
> http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/>
Bob asks:
We put them under <epicor_folder>\server\ud\{company}
for example:
D:\Program Files\Epicor\Epicor905\server\ud\UFM
or
D:\Program Files\Epicor\Epicor905\server\ud\TEST
Make sure to keep a backup of this folder just in case an upgrade
wipes it out!!!
Mark W.
That's the problem. Im just starting query's in vantage and have never really made ont. I do see the condition your speaking of.
I guess what im asking for is what would the actual query be. (when you click on "designed" and the query box shows up).
I really do appreciate any help with this. As I am drowning in other work.
Regards
Mark Trzaska
Administrator
425 Maple Avenue
Fax (847) 426-6951
Mark:
This is the simplest way to approach.
1. Create a new BAM on OrderRel, save it.
2. From available fields find NeedByDate and select it. ( screen 1)
3. In Action Click Send Alert. I would also do create log as it is good info for research.
4. Add your email in the To or CC box. ( screen 2 )
5. Make sure that Global Alerts Email Process is set to run at startup
6. Change a date on an order and you should get a generic alert. ( If there are errors they will be in the server log. Email errors show in the global alert messages error log )
7. Now add alert program attached into you \\server\Epicor905\server\ud<file:///\\server\Epicor905\server\ud> directory
8. Set the alert program to the same path and name ( screen 3)
9. Test again and you should get a formatted email. You can open the .p program in an editor and change the content, from, to, etc.
Good Luck
Greg Payne
Screen 1
[cid:image002.jpg@01CE4763.6F898160]
Screen 2
[cid:image004.jpg@01CE4763.6F898160]
[cid:image009.jpg@01CE4763.6F898160]
Sent: Thursday, May 02, 2013 3:24 PM
Regards
Mark Trzaska
Administrator
425 Maple Avenue
Fax (847) 426-6951
Thanx a million. I will keep you posted on results
Sent from my Windows Phone
Sent: �5/�2/�2013 5:31 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Cc: Trzaska, Mark<mailto:mtrzaska@...>
Subject: RE: Re: Request for basic Help
Mark:
Good Luck
Greg Payne
Screen 1
Screen 2
Regards
Mark Trzaska
Administrator
425 Maple Avenue
Fax (847) 426-6951
Thanx again
What I liked about bpm was I can design a template with pertinent order info. Can I do that with bam. Or like u said its very generic
Mark:
Good Luck
Greg Payne
Screen 1
Screen 2
Regards
Mark Trzaska
Administrator
425 Maple Avenue
Fax (847) 426-6951
Once you get the .p procedure running, then you can do any ABL code that you want on any table in the system. I left some of the formatting in the procedure commented out, since it all has to be converted to string for the body of the email. the ~n are new line and the ~t are tabs.
I had the old date and new date in the email as an example of referencing any of the before saved data as OLDtablename IE OLDOrderDtl.Neededbydate would be the previous date.
Greg
Sent: Thursday, May 02, 2013 10:02 PM
To: Greg Payne; vantage@yahoogroups.com
Subject: [Vantage] RE: Request for basic Help
Thanx again
Sent: ý5/ý2/ý2013 5:31 PM
Mark:
Good Luck
Greg Payne
Screen 1
Screen 2
Regards
Mark Trzaska
Administrator
425 Maple Avenue
Fax (847) 426-6951
Quick question. If I want to make it customer specific. Is that involve rewriting the .p code or modifying the bam.
Thanx again for all the help.
Regards,
Mark Trzaska
Sent: Thursday, May 02, 2013 5:33 PM
Cc: Trzaska, Mark
Mark:
Good Luck
Greg Payne
Screen 1
[cid:image001.jpg@...5E3380]
Screen 2
[cid:image002.jpg@...5E3380]
[cid:image003.jpg@...5E3380]
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com] On Behalf Of Trzaska, Mark
Regards
Mark Trzaska
Administrator
425 Maple Avenue
Fax (847) 426-6951
Customer ID is on the Order Header, so you can't set a rule to filter. add a condition in the .p to set sendemail = true when it is a customer you want an alert on.
You can also do an INDEX clause for a list of customers
Add after Find OrderHed - Find first Customer where Orderhed.custnum = Customer.Custnum no-lock.
Change
assign SendEmail = true.
to
If Customer.CustID = "XXX" then
Sent: Friday, May 03, 2013 5:09 PM
Subject: [Vantage] RE: Re: Request for basic Help
Regards,
Mark Trzaska
From: Greg Payne [mailto:GPayne@...<mailto:GPayne%40compulink-usa.com>]
Cc: Trzaska, Mark
Mark:
7. Now add alert program attached into you \\server\Epicor905\server\ud<file:///<file:///\\>\\server\Epicor905\server\ud> directory
Good Luck
Greg Payne
Screen 1
[cid:image001.jpg@...5E3380<mailto:image001.jpg%4001CE4816.EC5E3380>]
Screen 2
[cid:image002.jpg@...5E3380<mailto:image002.jpg%4001CE4816.EC5E3380>]
[cid:image003.jpg@...5E3380<mailto:image003.jpg%4001CE4816.EC5E3380>]
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Trzaska, Mark
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Regards
Mark Trzaska
Administrator
425 Maple Avenue
Fax (847) 426-6951
e-mail Mtrzaska@...<mailto:Mtrzaska%40StanleyMachining.com><mailto:Mtrzaska%40StanleyMachining.com><mailto:Mtrzaska@...<mailto:Mtrzaska%40StanleyMachining.com><mailto:Mtrzaska%40StanleyMachining.com>>
