Had to redeploy my app server in live. Now some reports, just mostly those in accounting, are having RptLabel errors and not working. Ideas on how to fix?
I’m guessing the reports are standard?
Have you tried syncing the report datasets from ‘Report Style’ menu
@KissFM @aidacra Yeah, wouldn’t sync. Kept giving me an error. System Report style is predefined. Unable to override.
Can you post the error?
Each report is slightly different, depending on what report you are running. I believe it is becaue my reports got converted to 10.1.500 reports and I am still in 10.1.400.19 for my live production. I am just not sure how to fix this, quickly.
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: System.Web.Services.Protocols.SoapException: An error has occurred during report processing. —> Microsoft.ReportingServices.ReportProcessing.ProcessingAbortedException: An error has occurred during report processing. —> Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: Query execution failed for dataset ‘Company’. —> System.Data.SqlClient.SqlException: Invalid column name ‘Calc_PPV’.
at Microsoft.ReportingServices.Library.ReportExecution2005Impl.InternalRender(String Format, String DeviceInfo, PageCountMode pageCountMode, Stream& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
at Microsoft.ReportingServices.Library.ReportExecution2005Impl.Render(String Format, String DeviceInfo, PageCountMode pageCountMode, Byte[]& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
at Microsoft.ReportingServices.WebServer.ReportExecutionService.Render(String Format, String DeviceInfo, Byte[]& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
Stack Trace:
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Ice.Core.SsrsReportService.ReportExecutionService.Render(String Format, String DeviceInfo, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds) in c:_Releases\ICE\3.1.400.19\source\Server\Internal\Lib\TaskLib\Web References\SsrsReportService\Reference.cs:line 633
at Ice.Core.SsrsReporting.SsrsRendererBase.Render(SsrsRenderInformationBase renderInformation) in c:_Releases\ICE\3.1.400.19\source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 141
at Ice.Core.SsrsReporting.SsrsRendererBase.<>c__DisplayClass2.b__0() in c:_Releases\ICE\3.1.400.19\source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 87
at Epicor.Hosting.Trace.TraceHandle.TimeAction(Action actionToTime) in c:_Releases\ICE\3.1.400.19\source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 91
at Epicor.Hosting.Trace.TraceHandle.AddTimedIfEnabled(String traceFlag, Action actionToTime, Func2 messageBuilder) in c:\_Releases\ICE\3.1.400.19\source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 43 at Ice.Core.SsrsReporting.SsrsRendererBase.TraceReportRendered(String printProgram, String ssrsRenderFormat, Func
1 timedAction) in c:_Releases\ICE\3.1.400.19\source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 95
at Ice.Core.SsrsReporting.ReportProcessorBase1.ProcessReportPart(String reportLocation) in c:\_Releases\ICE\3.1.400.19\source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 161 at Ice.Core.SsrsReporting.StandardReportProcessor
1.ProcessReportParts() in c:_Releases\ICE\3.1.400.19\source\Server\Internal\Lib\TaskLib\SsrsReporting\StandardReportProcessor.cs:line 33
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder1.ProcessUnroutedReport() in c:\_Releases\ICE\3.1.400.19\source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 215 at Ice.Core.RptBase.ReportDatabaseBuilder
1.XMLClose() in c:_Releases\ICE\3.1.400.19\source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 134
at Ice.Core.RptTaskBase1.XMLClose() in c:\_Releases\ICE\3.1.400.19\source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 134 at Erp.Internal.AP.APR10.RunProcess(Int64 instanceTaskNum, String outputFileName) in c:\_Releases\ERP\RL10.1.400.0\Source\Server\Internal\AP\APR10\APR10.cs:line 321 at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in c:\_Releases\ICE\3.1.400.19\source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 78 at Ice.Hosting.TaskCaller.ExecuteTask(Boolean suppressTransaction) in c:\_Releases\ICE\3.1.400.19\source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 31 at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in c:\_Releases\ICE\3.1.400.19\source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63 at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in c:\_Releases\ICE\3.1.400.19\source\Server\Services\Lib\RunTask\RunTask.cs:line 502 at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in c:\_Releases\ICE\3.1.400.19\source\Server\Services\Lib\RunTask\RunTask.cs:line 502 at Ice.Services.Lib.RunTaskSvcFacade.RunTask(Int64 ipTaskNum) in c:\_Releases\ICE\3.1.400.19\source\Server\Services\Lib\RunTask\RunTaskSvcFacade.cs:line 99 at SyncInvokeRunTask(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func
2 func) in c:_Releases\ICE\3.1.400.19\source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in c:_Releases\ICE\3.1.400.19\source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in c:_Releases\ICE\3.1.400.19\source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage31(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.ServiceModel.Channels.SocketConnection.OnReceiveAsync(Object sender, SocketAsyncEventArgs eventArgs)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Did you check the Data Source of the offenders in Report Manager?
Click the pulldown of the report items and click ‘Manage’ to find this screen. I’ve had trouble in the past where the data source still pointed to the Test environment. I had to manually update them.
Ben
