Report Writer Automation?
If you name the report with a prefix of "TXT-", AutoRpts prints this straight to "the reportname.TXT" file in the directory you setup. This should be the same result as doing an export from Report Builder itself. If you need additional help on AutoRpts, please contact me off list.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of ecfmis
Sent: Monday, October 24, 2005 1:21 PM
Subject: [Vantage] Re: Report Writer Automation?
We have autoreports, but will the text file be in the same format as
the export function in report writer? The reason I ask, is we will
be using this file to import into excel.
--- In vantage@yahoogroups.com, "Podlin, Michael"
<michael.podlin@v...> wrote:
> Yes this can be done, but you'll need to create a progress
procedure to run it, then schedule to launch your progress procedure.
> I run about 75 reports after hours with an application called
AutoRpts, to specific printers throughout the shop, to files
(.TXT, .CSV, .PDF, .XML), send to e-mail addresses, create web
pages, create graph generated images or printouts, etc.
Behalf
> Of ecfmis
> Sent: Monday, October 24, 2005 12:34 PM
> Subject: [Vantage] Report Writer Automation?
> Is it possible to run a report in report writer on a nightly basis
but
> have the result in a text file like the "Export" option within
report
> builder? If so what would the command line look like?
> Thanks,
> Tim
Yahoo! Groups Links
Is it possible to run a report in report writer on a nightly basis but
have the result in a text file like the "Export" option within report
Tim
Yes this can be done, but you'll need to create a progress procedure to run it, then schedule to launch your progress procedure.
I run about 75 reports after hours with an application called AutoRpts, to specific printers throughout the shop, to files (.TXT, .CSV, .PDF, .XML), send to e-mail addresses, create web pages, create graph generated images or printouts, etc.
Of ecfmis
Tim
Behalf
> Of ecfmis
but
report
> Thanks,
> Tim
