Report Viewing Problem
I know this reply comes a bit late but... I always had the same error, until I reviewed my "System Task Agent" settings in my application.
Be sure that the setup of the Server File , Client File and Client Directory paths are set correctly.
If you change them, don't forget to shutdown and restart. Hope that helps!
Holly R.
----- Original Message ----
Sent: Sunday, July 1, 2007 3:13:22 PM
Subject: RE: [Vantage] Report Viewing Problem
> We just migrated our Vantage 8.0 to a new server. Everything works
> fine, except when viewing or printing reports. Doesn't matter if it's
> a Progress report or Crystal, it always gives me a system error with
> the details below. I know it produces the report, because they are
> sitting in the right folder and the folder is completely shared. For
> some reason it can't seem to see that folder.
> However, I can print if I login from the server itself. It seems to
> be path issue, but I don't know where to set it.
> Thanks in advance for your help.
It's the Path listed in your System Agent. It must begin with the
\\ServerName\ MfgSysData\ .
Mark W.
____________________________________________________________________________________Ready for the edge of your seat?
Check out tonight's top picks on Yahoo! TV.
http://tv.yahoo.com/
Error Detail
Could not find a part of the path
"C:\epicor\mfgsysdata\Reports\userX\Check Register19853.TXT".
Stack Trace
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileStream..ctor(String path, FileMode mode,
FileAccess access, FileShare share, Int32 bufferSize, Boolean
useAsync, String msgPath, Boolean bFromProxy)
FileAccess access, FileShare share)
at Epicor.Mfg.Lib.Report.EpiTextDocument..ctor(String filename,
Int32 linesPerPage, Session currentSession)
at
Epicor.Mfg.UI.App.SysMonitorEntry.Transaction.checkIfDocumentLoaded(String
rptFile, Int32 maxLinesPerPage)
at Epicor.Mfg.UI.App.SysMonitorEntry.Transaction.previewTxtReport()
\\ServerName\MfgSysData\.
Mark W.
