I currently have one with two sub reports...I needed to make sure the details from both sub reports align in the main report and then the main report can be exported to Excel - is this what you are looking for or are you wanting to export the output from the sub reports instead?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Rick Hagy
Sent: Thursday, May 19, 2011 3:16 PM
Subject: RE: [Vantage] Report to Exel
It will export till I add sub reports then it stops working.
Rick Hagy
Project Manager
Tel: (804) 523-8115
Fax: (804) 523-8150
http://www.openplan.com <http://www.openplan.com/>
HMU, LLC d/b/a Open Plan Systems
4700 Deepwater Terminal Rd | Richmond, VA 23234
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Karen Schoenung
Sent: Thursday, May 19, 2011 3:19 PM
If you align the columns up nicely and choose the "data only" option, it
will usually work...If your columns do not match up exactly, make sure
the header and data columns are the same width (even squish on the
preview if users normally will export anyway).
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of Rick
Sent: Thursday, May 19, 2011 2:15 PM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Subject: [Vantage] Report to Exel
I am trying to create a crystal report for an inventory report.
Onhand OpenPO InvTran
I am using sub reports.
When i run the report and try to export to Exel it will not work, does
anyone know a work around?
Rick
Rick Hagy
Project Manager
Tel: (804) 523-8115
Fax: (804) 523-8150
Of Karen Schoenung
Behalf Of Rick
Rick
