Report Server Error
Has anyone seen an error like the following?
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: Server was unable to process request. ---> Method ReportExecutionService.GetDocumentMap can not be reflected. ---> There was an error reflecting 'result'. ---> Could not load file or assembly 'Microsoft.ReportingServices.ProcessingCore' or one of its dependencies. There is not enough space on the disk. (Exception from HRESULT: 0x80070070)
Stack Trace:
   at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
   at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
   at Ice.Core.SsrsReportService.ReportExecutionService.LoadReport(String Report, String HistoryID) in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\Web References\SsrsReportService\Reference.cs:line 287
   at Ice.Core.SsrsReporting.SsrsRendererBase.ConfigureReportServerForReport(String reportPath, ParameterValue[] parameters) in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 163
   at Ice.Core.SsrsReporting.SsrsSingleDocumentRenderer.<>c__DisplayClass1_0.<RenderDocument>b__0() in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsSingleDocumentRenderer.cs:line 49
   at Ice.Core.SsrsReporting.SsrsRendererBase.<>c__DisplayClass12_0.<TraceReportRendered>b__0() in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 87
   at Epicor.Hosting.Trace.TraceHandle.TimeAction(Action actionToTime) in C:\_Releases\ICE\ICE3.2.400.0\Source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 92
   at Epicor.Hosting.Trace.TraceHandle.AddTimedIfEnabled(String traceFlag, Action actionToTime, Func`2 messageBuilder) in C:\_Releases\ICE\ICE3.2.400.0\Source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 39
   at Ice.Core.SsrsReporting.SsrsRendererBase.TraceReportRendered(String printProgram, String ssrsRenderFormat, Func`1 timedAction) in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 95
   at Ice.Core.SsrsReporting.ReportProcessorBase.RenderReportForPreviewOrGenerate(RenderedSsrsReport renderedReport) in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 264
   at Ice.Core.SsrsReporting.ReportProcessorBase.ProcessReportPart(String reportLocation) in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 158
   at Ice.Core.SsrsReporting.StandardReportProcessor.ProcessReportParts() in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\SsrsReporting\StandardReportProcessor.cs:line 31
   at Ice.Core.RoutingAndBreaking.ReportPersister.Persist(ReportInstanceInformation reportInstance, Func`2 reportsRenderer, Action`1 fillSysRptLstRow, Action`2 processReport, Func`3 filterTableAttachmentsFunc) in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ReportPersister.cs:line 57
   at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RenderUnroutedSsrsReport() in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 303
   at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RunSsrsReportIfEnabled() in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 228
   at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.ProcessReportWithDataInPlace(Func`2 executeCommand, Func`2 executeReader, SqlObjectsCreated sqlObjectsCreated) in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 111
   at Ice.Core.RptBase.ReportDatabaseBuilder.XMLClose() in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 93
   at Ice.Core.RptTaskBase`1.XMLClose() in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 229
   at Erp.Internal.JC.JobTrav.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:\_Releases\ERP\ERP10.2.400.0\Source\Server\Internal\JC\JobTrav\JobTrav.cs:line 690
   at Ice.Core.TaskBase`1.StartProcess(Int64 instanceTaskNum, String outputFileName) in C:\_Releases\ICE\ICE3.2.400.9\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskBase.cs:line 47
   at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:\_Releases\ICE\ICE3.2.400.9\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 98
   at Ice.Hosting.TaskCaller.ExecuteTask() in C:\_Releases\ICE\ICE3.2.400.9\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 57
   at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:\_Releases\ICE\ICE3.2.400.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
   at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:\_Releases\ICE\ICE3.2.400.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 592
Well, that part jumps out at me.
No idea if it is referring to a disk on the App server, or the SQL server. Or possibly the DB’s alloted size.
Not seeing any of these as without enough space… I checked on that first thing.
Is this a new report you’re working on, or one that has run without issues in the past?
Just double check everything
  1. SQL Server
  2. App Server
  3. Task Agent Server
  4. SSRS Server
  5. SSRS SQL Server
Check also the Temp File Directories (some people have their temp files go to different locations)… if all looks okay then go to your SQL Setting perhaps it’s not set to auto-grow and the database has reached its limit.
If you are virtualized perhaps the Host is out of disk-space and your Guest OS doesnt reflect that.
It definitely should be disk space related.
So, we’re still working out where the problem was specifically, but after restarting all services on the App Server & even rebooting entire machine (VM) no joy. Last resort was to reboot the SQL server which resolved the issue. Just looking to determine the exact cause now.
Thank you both for your suggestions!
SQL Server reboot resolved it? I’d guess TempDB max size reached or out of disk space. SQL Server logs or Event Logs might give more details.
