Report Quantity MES 10.1.600.8
Can anyone confirm if Report Quantity button is available in MES in 10.1.600.8?
We were testing at that level and they said there is a but slated to be fixed somewhere in 10.2
However I went back to testing at 10.1.500 and the button is still not available to click and report quantity.
It’s in 10.1.600.5. I don’t know how functional it is, as we don’t use it, but I can click the button and the window pops up. (we never really liked how it worked, so we don’t use that function)
Did you verify the Employee record has the “Report Quantity” option checked in employee setup? The button should only be available if that is checked.
Yes, that is checked along with override also.
Did you Start Production Activity first?
Yes.
We had this issue after our migration from E9 to E10. It was due to a customization record not being properly set for the MES main screen.
Do you have any customization’s on the MES screen?
No, it is the base form on a new install.
I can confirm that the Report Qty button in 10.1.600.8 and 10.1.600.9 do work.
Support now told me I need to license and activate Advanced Material Management & Advanced Inventory Management Module. It is working now with just activating Advanced Inventory on our test setup.
