Report Data Definitions
oops, sorry about that garbled stuff on bottom...Its the gridview of what my proposed dashboard looks like comparing a system RDD of PackSlip to a Modified of PackSlip where I added SNTran table and added some fields to OrderDtl.
When I get that dashboard written I will put it out on site.
----- Original Message -----
Sent: Friday, August 28, 2009 2:44 PM
Subject: Re: [Vantage] Re: Report Data Definitions
Wow, I am sooo glad I brought up this discussion. This is great. Is this general knowledge? I didn't even know this existed? Where has this been? I have always re-created the definition in Live....ugh? When you say you "imported" it? ok for SQL for Progress? So once the definition is there is it useable by a modified crystal report that uses it. i.e. I have modified the RDD for PackList that includes other fields, other tables, addl criteria,et. I'm a little leary....
Why wouldn't this just be a command within the RDD??? Actions Export.
So now my real question hasn't been answered...Once I have my RDDs how has everyone kept track of the changed RDD compared to the System RDD. So what I was thinking is creating a dashboard that compares the two...
i.e. RDD PackSlip to Modified Packslip1.
Report Definition Description System Report Type Report Definition Description System Report Type Duplicate Of
PackSlip Packing Slip TRUE Crystal PackSlp Packing Slip Modified FALSE Crystal PackSlip
Rpt Table ID Sequence Primary Table SystemFlag Rpt Table ID Sequence Primary Table SystemFlag
Company 10 FALSE TRUE Company 10 FALSE TRUE
CustomerDocs 900 TRUE FALSE CustomerDocs 900 TRUE FALSE
OrderDtl 110 FALSE TRUE OrderDtl 0 FALSE FALSE
Packing 70 FALSE TRUE Packing 70 FALSE TRUE
rptttLabelSeq 100 FALSE TRUE rptttLabelSeq 100 FALSE TRUE
ShipCOO 90 FALSE FALSE ShipCOO 90 FALSE FALSE
ShipDtl 40 TRUE TRUE ShipDtl 40 TRUE TRUE
ShipDtlTax 10 FALSE FALSE ShipDtlTax 10 FALSE FALSE
ShipHead 30 FALSE TRUE ShipHead 30 FALSE TRUE
ShipMisc 80 FALSE TRUE ShipMisc 80 FALSE TRUE
ShipRestriction 120 FALSE FALSE ShipRestriction 120 FALSE FALSE
SNTran 0 FALSE FALSE
SubstRestriction 130 FALSE FALSE SubstRestriction 130 FALSE FALSE
Sent: Friday, August 28, 2009 1:48 PM
Subject: RE: [Vantage] Re: Report Data Definitions
Thanks, Jim! I'll have to play with it next week. Almost beer thirty
on the east coast. ;-)
Of jmpratt7
Sent: Friday, August 28, 2009 1:33 PM
Subject: [Vantage] Re: Report Data Definitions
I just downloaded the referenced report and got it to work. The
connection string wants three things:
Data Source=<Your Vantage Server Name>;
Initial Catalog=<Your Database Name: MfgSys803, MfgTrain803, etc>;
Trusted_Connection=True
I found a definition I had on one database that wasn't in the other,
exported it, then imported it into the other system. Worked like a
charm! Where was this during my last upgrade!
Regards,
Jim Pratt
--- In vantage@yahoogroups.com, "lisserjm" <Jennifer.Lisser@...> wrote:
> Vic,
> I found a report data definition exporter in the files on this user
site
(http://tech.groups.yahoo.com/group/vantage/files/Reports%20-%20Report%2
0Export%20Utilit/). I did the install and ran it - it was looking for an
ODBC source and the string we use didn't work. I got distracted with
other things and never made it back to look at it further. Have you
looked into it?
> Jenn
> --- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@> wrote:
> > My procedure is a good backup of the database. :-)
> > That's a great question and brings me back to another item on my
Vantage
> > wishlist: The ability to export Report Data Definitions to XML as
we
> > can BAQs.
> > For most I do a screen print in Excel. It's certainly not
bulletproof.
I have added a combo box to the Quote entry screen that allows our Quote guy
to select an FOB from the FOB table. Everything seems to be working fine I
have it being displayed on the quote so it is getting entered into the DB
but if he clears the screen and goes back to the quote field displays the no
value selected option. Instead of what he entered the last time he was
working on the quote. I have scoured the setting for the combo box and
nothing popped out at me saying change this setting. Can someone tell me
what I'm missing. I have compared all the settings to the Shipvia combo box
and everything seems to be set the same. Except for the fields that have to
be different.
Thanks!
~Charlie
I'm really puzzled by this one any ideas?
~Charlie
_____
Charlie Wilson
Sent: Tuesday, August 25, 2009 2:24 PM
Subject: [Vantage] Combo Box Custimazition 407
be different.
Thanks!
~Charlie
Hi Charlie,
You feel like forwarding me the customization? I'd like to take a look.
smcdanie@...
--Sean
Charlie Wilson
Sent: Thursday, August 27, 2009 4:12 PM
Subject: RE: [Vantage] Combo Box Custimazition 407
~Charlie
_____
Behalf Of
Charlie Wilson
be different.
Thanks!
~Charlie
Did you run a BAQ to double check and make sure that FOB code actually
got saved in the quote?
Of Charlie Wilson
~Charlie
_____
Behalf Of
Charlie Wilson
guy
I
DB
the no
box
to
be different.
Thanks!
~Charlie
Alison Levy | IT Manager | Mats Inc.
dir: 781-573-0291 | cell: 781-964-1698 | fax: 781-232-5191
alevy@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Built a fast crystal but yes.
~Charlie
_____
Alison Levy
Sent: Friday, August 28, 2009 9:03 AM
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Charlie Wilson
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
~Charlie
_____
Behalf Of
Charlie Wilson
guy
I
DB
the no
box
to
be different.
Thanks!
~Charlie
alevy@matsinc. <mailto:alevy%40matsinc.com> com | www.matsinc.com Ask us
of the company.
Did you add an Ultra Combo or just a Combo box?
Sent: Friday, August 28, 2009 9:25 AM
~Charlie
_____
Alison Levy
Behalf
Of Charlie Wilson
~Charlie
_____
Behalf Of
Charlie Wilson
guy
I
DB
the no
box
to
be different.
Thanks!
~Charlie
of the company.
Combo cuz that is what the ship via field is but I'm switching to ultra
right now.
~Charlie
_____
advantage
Sent: Friday, August 28, 2009 9:28 AM
Subject: Re: [Vantage] Combo Box Custimazition 407
~Charlie
_____
Behalf Of
Alison Levy
Behalf
Of Charlie Wilson
~Charlie
_____
Behalf Of
Charlie Wilson
guy
I
DB
the no
box
to
be different.
Thanks!
~Charlie
of the company.
What is everyone's procedure on keeping track of modified Report Data Definitions; i.e. what fields you added; what tables you added; what criteria you added. I was thinking of writing a Dashboard like I have one for BAQ Queries
that shows me a quadrant for Queries, a quadrant for those queries tables, fields, criteria, etc....
Nice thing about Customizations you can keep track of what was done in Notes (E9). Maintenance you can pull up a Customization and show the Custom Data. Looking for a similar process?
Yes, that might be your issue. Ultra Combo requires a retriever to go get the FOB info. When just doing a combo you have to provide a static list and it doesn't live anywhere in the DB?
Sent: Friday, August 28, 2009 9:35 AM
right now.
~Charlie
_____
advantage
~Charlie
_____
Behalf Of
Alison Levy
Behalf
Of Charlie Wilson
~Charlie
_____
Behalf Of
Charlie Wilson
guy
I
DB
the no
box
to
be different.
Thanks!
~Charlie
of the company.
That's a great question and brings me back to another item on my Vantage
wishlist: The ability to export Report Data Definitions to XML as we
can BAQs.
For most I do a screen print in Excel. It's certainly not bulletproof.
Of advantage
Subject: [Vantage] Report Data Definitions
one for BAQ Queries
<< The ability to export Report Data Definitions to XML as we
can BAQs.
CAN WE GET AN AMEN BROTHER!!
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Vic Drecchio
Sent: Friday, August 28, 2009 8:51 AM
Subject: RE: [Vantage] Report Data Definitions
can BAQs.
Behalf
Of advantage
one for BAQ Queries
AMEN.
(Can't make the font big enough to properly express the emphasis of that
exclamation)
Of Rob Bucek
Sent: Friday, August 28, 2009 7:44 AM
can BAQs.
Rob Bucek
FAX: (715)284-4084
Behalf
Of Vic Drecchio
can BAQs.
Behalf
Of advantage
one for BAQ Queries
Click here
<https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==
7U86beVUNzVDP3rmH4MRqpGbGRkBgWkMri!i5jK2rp2Ftw==> to report this email
as spam.
This message has been scanned for malware by SurfControl plc. www.surfcontrol.com
Vic,
I found a report data definition exporter in the files on this user site (http://tech.groups.yahoo.com/group/vantage/files/Reports%20-%20Report%20Export%20Utilit/). I did the install and ran it - it was looking for an ODBC source and the string we use didn't work. I got distracted with other things and never made it back to look at it further. Have you looked into it?
Jenn
> can BAQs.
Hey Jenn, thank you very much!
Actually, I have seen that and ran against the same wall you did. I
gave up. If I really wanted to, I guess I could write something in SQL
to mimic this process. Thanks for the reminder!
Vic
Of lisserjm
Sent: Friday, August 28, 2009 11:56 AM
Vic,
looked into it?
Jenn
Vantage
> can BAQs.
bulletproof.
I just downloaded the referenced report and got it to work. The connection string wants three things:
I found a definition I had on one database that wasn't in the other, exported it, then imported it into the other system. Worked like a charm! Where was this during my last upgrade!
Regards,
Jim Pratt
> Vic,
> Jenn
> > can BAQs.
Of jmpratt7
Regards,
Jim Pratt
> Vic,
site
looked into it?
> Jenn
Vantage
we
> > can BAQs.
bulletproof.
Of jmpratt7
Regards,
Jim Pratt
> Vic,
site
looked into it?
> Jenn
Vantage
we
> > can BAQs.
bulletproof.
