Sorry, Worng topic.
Â
Jonathan LangÂ
Oil Rite Corporation
Sr. Network Administrator
Ph: (920) 682-6173 Ext: 126
Fax: (920) 682-7699
 Â
Â
Jonathan LangÂ
Fax: (920) 682-7699
 Â
--- On Tue, 1/6/09, Jonathan Lang <lsbestinc@...> wrote:
Subject: Re: [Vantage] Re: Report Data Definition Question
Date: Tuesday, January 6, 2009, 2:07 PM
This is a space issue and I can understand why the techs at Epicor increase or change the settings. The problem is usually do to setup and the defaults associated with it. In order to rid your self of the problem you need to increase the table size. If you are not familiar on how to do this PLEASE call support and have them do this for you.
Â
Understand that this is a problem that occurs in many Database programs. I have incountered it in SAP, Oracle, SQL and Progress. SOmetimes the settings can be tricky and may need to be played with to find the right size.
Â
Jonathan LangÂ
Fax: (920) 682-7699
 Â
--- On Tue, 1/6/09, Dave Eaton <deaton@dentonvacuum .com> wrote:
Subject: [Vantage] Re: Report Data Definition Question
To: vantage@yahoogroups .com
Date: Tuesday, January 6, 2009, 1:19 PM
--- In vantage@yahoogroups .com, "Dave Eaton" <deaton@...> wrote:
> I'm trying to create a duplicate of the Stock Status report in
Vantage
> 803.405a so I can add the bin location to the report. I created a
new
> report data definition as a duplicate of the original stock status
> report but none of the tables, calculated fields etc. show up in the
> new report. Shouldn't this new report be an exact duplicate of the
> original Stock Status report? Am I missing something here?
Thanks All. I was doing it wrong. I selected "new report"
then "duplicate of". Didn't see the other selection from the actions
menu. Works fine now.
Thanks again.
