Its my understanding that you have to own SDK to see the calc fields.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of tom.sederquist@...
Sent: Tuesday, November 05, 2013 6:05 PM
Subject: RE: RE: [Vantage] RE: Report Calculated Fields
Is there any way to view the formula for the calculated field without the developer program? I would like to know which fields are being brought into the formula so that I can determine where the data is being pulled from.
---In vantage@yahoogroups.com, <cathy@...> wrote:
What is the name of the field you are trying to change? If it is a calculated report field (like Calc_PartDescription) you can’t change it in the Report Data Definition without some developer program.
Find the database field that you need and replace the report calculated field on the report. It might be excluded from the table – so you might have to add it Report Table > Excluded Fields.
I not sure if you will need a formula.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of smyers@...
Sent: Tuesday, November 05, 2013 10:19 AM
Subject: [Vantage] RE: Report Calculated Fields
Thanks for your suggestion, but this does not solve my problem. The report is not a BAQ report, but a duplicate of a standard report data definition (BOMListing), with just a few tweaks compared to the standard report.
Steven
---In vantage@yahoogroups.com, <pjw@...> wrote:
If it’s from a BAQ make sure it’s also formatted for more than 30 characters.
Patrick Winter
Sent: Monday, November 04, 2013 04:44
Subject: [Vantage] Report Calculated Fields
Does anyone know how to see changes made to a report calculated field actually in effect on a crystal report?
I have changed the format of a character field from x30 to x500 but it still shows x30 in the report. This is for a description field which must be shown in full.
Epicor 9.05.702
Steven
