Maybe it's the directory "Ver 51 RB", try changing to "Ver51RB".
Different OS's may handle the spaces differently (?).
When in doubt, reinstalling Progress/Vantage on the workstation
wouldn't hurt.
wouldn't hurt.
--- In vantage@y..., Britt Moelling <bmoelling@m...> wrote:
> We are trying to make an Icon to allow us to run Report Builder
Reports
> outside of Vantage using the following command line:
> V:\Progress\bin\prowin32.exe V:\Vantage\db\vantage.db -p
> V:\vantage\RBDT\CRJournalSumWF.p -S epic51 -H mark4 -N TCP
> This works on our Report Builder Developer's workstation (Win 98),
but
> not on any other workstation (all happened to be Win 2K). I don't
see
> how the OS could matter.
> On the Report Builder Developer's workstation (without Vantage
running),
> the filters box pops up etc. But on any other machine, we
get "Powered
> by Progress" splash screen, then the dialog box from within the .p
file,
> but nothing happens after the code is executed. It just seems to
> vanish, no errors, no output, nothing running in Task Manager!
> Any ideas?
> The .p file is :
> DEF VAR RB-REPORT-NAME AS CHARACTER INITIAL "".
> DEF VAR RB-DB-CONNECTION AS CHARACTER INITIAL "".
> DEF VAR RB-INCLUDE-RECORDS AS CHARACTER INITIAL "?".
> DEF VAR RB-FILTER AS CHARACTER INITIAL "".
> DEF VAR RB-MEMO-FILE AS CHARACTER INITIAL "".
> DEF VAR RB-PRINT-DESTINATION AS CHARACTER INITIAL "".
> DEF VAR RB-PRINTER-NAME AS CHARACTER INITIAL "".
> DEF VAR RB-PRINTER-PORT AS CHARACTER INITIAL "".
> DEF VAR RB-OUTPUT-FILE AS CHARACTER INITIAL "".
> DEF VAR RB-NUMBER-COPIES AS INTEGER INITIAL 1.
> DEF VAR RB-BEGIN-PAGE AS INTEGER INITIAL 0.
> DEF VAR RB-END-PAGE AS INTEGER INITIAL 0.
> DEF VAR RB-TEST-PATTERN AS LOGICAL INITIAL no.
> DEF VAR RB-WINDOW-TITLE AS CHARACTER INITIAL "".
> DEF VAR RB-DISPLAY-ERRORS AS LOGICAL INITIAL yes.
> DEF VAR RB-DISPLAY-STATUS AS LOGICAL INITIAL yes.
> DEF VAR RB-NO-WAIT AS LOGICAL INITIAL no.
> DEF VAR RB-OTHER-PARAMETERS AS CHARACTER INITIAL "".
> DEF var report-library AS CHARACTER.
> DEF VAR report-list AS CHARACTER.
> DEF VAR report-count AS INTEGER.
> DEF VAR report-number AS INTEGER.
> DEF VAR display-rep-name AS CHARACTER INITIAL "".
> DEF VAR button-select AS LOGICAL INITIAL YES.
> /*report-library = "V:\vantage\Ver 51 RB\ar.prl".
> RB-Report-name = "ar terms list".
> display-rep-name = "M&M AR Terms List".*/
> RB-Report-name = "C R Journal Summary[WF]9x".
> display-rep-name = "CASH Journal Summary - WF".
> MESSAGE "Run Report : " display-rep-name " ?" SKIP(0)
> VIEW-AS ALERT-BOX QUESTION BUTTONS OK-CANCEL UPDATE
> button-select.
> IF button-select = YES THEN DO:
> /*RB-INCLUDE-RECORDS = "S".*/
> RB-INCLUDE-RECORDS = "?".
> RB-Print-Destination = "D".
> /*RB-Print-Destination = "".*/
> RB-filter = "".
> RUN aderb/_printrb.p (report-library,
> RB-REPORT-NAME,
> RB-DB-CONNECTION,
> RB-INCLUDE-RECORDS,
> RB-FILTER,
> RB-MEMO-FILE,
> RB-PRINT-DESTINATION,
> RB-PRINTER-NAME,
> RB-PRINTER-PORT,
> RB-OUTPUT-FILE,
> RB-NUMBER-COPIES,
> RB-BEGIN-PAGE,
> RB-END-PAGE,
> RB-TEST-PATTERN,
> RB-WINDOW-TITLE,
> RB-DISPLAY-ERRORS,
> RB-DISPLAY-STATUS,
> RB-NO-WAIT,
> RB-OTHER-PARAMETERS).
> END.
> ELSE DO:
> QUIT.
> RETURN.
> END.
> QUIT.
> RETURN.
> Britt Moelling
> M&M Manufacturing Co.
