Sorry, forgot about the middle step with the aggregate due to restriction on
refering to Filter function in another function. I use the "minimum"
aggregate to create PrtFilter and then manipulate that. I should have
looked at an example to get all the steps before replying.
-Todd C.
Sent: Tuesday, October 31, 2000 4:39 PM
To: vantage@egroups.com
Subject: Re: [Vantage] Report Builder: Printing Criteria used in Filter
Todd -
Please confirm. I haven't found a way to reference a calc
field of the REPORT-FILTER in a second calc field using
SUBSTRING - without moving the value through an
aggregate. In essence, I haven't found a way to do:
SUBSTRING(REPORT-FILTER(), x, y)
Please advise - the way I just posted is very tedious to set
up for multiple filters. Would love a short cut.
Thx,
Calvin
-Todd C.
Todd -
Thx,
Calvin
----- Original Message -----
To: <vantage@egroups.com>
Sent: Tuesday, October 31, 2000 4:14 PM
Subject: RE: [Vantage] Report Builder: Printing Criteria used in Filter
> I'll expand on the previous reply - use the Index and Substring functions.
> Because the text will be fairly static (unless you are adding filters at
run
> time) you can search for various starting positions of known phrases and
> takes the n-th thru n-th+whatever characters. To keep it all clear you
may
> want to make seperate calculations for various starting and ending
positions
> and use them in the final substring calculation. Once you have the
"clear"
> text values you can string them together as a final phrase such as -
> Report from 10/01/00 to 10/31/00 -
> -Todd C.
> From: Todd Caughey [mailto:caugheyt@...]
> Sent: Tuesday, October 31, 2000 3:59 PM
> To: 'vantage@egroups.com'
> Yes, I do it all the time. There is a function REPORT-FILTER() which you
> can use in a Calculated field (I call PrtFilter) and include in the
> Page-Header or the report footer. The results are often wordy and use
> database field names but are usually understandable. If you know what to
> string search for you can parse out the bits you want into a friendler
> format.
> -Todd C.
> From: Brian Stenglein [mailto:bstenglein@...]
> Sent: Tuesday, October 31, 2000 3:14 PM
> Subject: [Vantage] Report Builder: Printing Criteria used in Filter
> Is it possible to print the values used in the filter. I want to
> show the date range that we are printing this report for.
> Thanks,
> Brian Stenglein
> We no longer allow attachments to files. To access/share Report Files,
> please go to the following link: http://www.egroups.com/files/vantage/
<http://www.egroups.com/files/vantage/>
> < http://www.egroups.com/files/vantage/
<http://www.egroups.com/files/vantage/> >
<http://www.egroups.com/files/vantage/> > >
> (Note: If this link does not work for you the first time you try it, go
to
> www.egroups.com, login and be sure to save your password, choose My
Groups,
> choose Vantage, then choose Files. If you save the password, the link
above
> will work the next time you try it.)
> eGroups Sponsor
> < http://click.egroups.com/1/9648/13/_/411782/_/973029570/
<http://click.egroups.com/1/9648/13/_/411782/_/973029570/> >
http://adimg.egroups.com/img/9648/13/_/411782/_/973029570/TargetSoftware468
<http://adimg.egroups.com/img/9648/13/_/411782/_/973029570/TargetSoftware468
> x602F.gif>
to
Groups,
above
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
eGroups Sponsor
<http://click.egroups.com/1/8657/13/_/411782/_/973032257/>
<http://adimg.egroups.com/img/8657/13/_/411782/_/973032257/468x60_Family.gif
