Report builder help- try not to show 0 on a report
Linda,
Create 2 calculated fields and use the absolute value function to get the value positive. In the same calculation, use an if-then statement to designate whether it is a debit or a credit.
For example,
credit calculation,
IIF(amount < 0,ABSOLUTE(amount),?)
debit calculation
IIF(amount >= 0,amount,?)
Put them on top of each other, one set under debit and one set under credit.Make sure that you format unknowns to be blank.
To eliminate zeros, you can just place a filter to not show amount=0.
Jasper
Sent: Wednesday, October 26, 2005 11:41 AM
Subject: [Vantage] Report builder help- try not to show 0 on a report
Hello,
Regarding the negative amounts, you could create a formula something like this: if number < 0 then number * -1 and this will reverse the sign so that it shows as a positive number.
Linda
You wrote:
I'm writing a G/L report and am creating a debit and credit column.
Firstly I want the - transaction amount to show a number without the
negative sign and secondly data that is 0.00 to be blank...
Please help!!
Yahoo! Groups Links
Please help!!
So far
IIF(TransAmt <= 0 , (TransAmt - TransAmt - TransAmt) , 0 ).
The only way with my knowledge to change the - amount to a positive number
was to do the above
The next problem I have is anything 0 is showing up with 0.00 which I just
want blank
So I tried to do a string command to take out the 0
iif(string (debit)="0","",string (debit)) this work ok but now If format of
a field is say 9 character wide and the number is say 32.42 it shows a
32.42000 or 4432.10 show as 4432.100
Tried converting them back to numbers and I get the 0.00 entry's back
Regards,
Mark Howard
Jaws Buckets & Attachments
10 Willingdon st
Brisbane
Australia
Hi Mark,
Add as part of your calculation string((integer(debit *
100))/100) and you'll get your two digit decimal as a string. Depending on
how touchy the "rounding" issue is you may have to add the "ROUND" function
to the calculation.
Shirley Graver
Rubber Associates Inc.
_____
Mark Howard
Sent: Monday, October 24, 2005 6:23 PM
To: 'vantage@yahoogroups.com'
Please help!!
So far
was to do the above
want blank
Regards,
Mark Howard
10 Willingdon st
Brisbane
Australia
SPONSORED LINKS
Manufacturing
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing
+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=P
da+database+software&w5=Database+management+software&w6=Database+marketing+s
oftware&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software
Membership
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufac
turing+software&w2=Membership+database+software&w3=Database+mortgage+softwar
e&w4=Pda+database+software&w5=Database+management+software&w6=Database+marke
ting+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+software&
w4=Pda+database+software&w5=Database+management+software&w6=Database+marketi
ng+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
Pda
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+
software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pd
a+database+software&w5=Database+management+software&w6=Database+marketing+so
ftware&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufac
ting+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufact
uring+software&w2=Membership+database+software&w3=Database+mortgage+software
&w4=Pda+database+software&w5=Database+management+software&w6=Database+market
ing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage <http://groups.yahoo.com/group/vantage> "
on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
_____
Tracking #: 53F7B937ED71CE4FA316A7A7951327FB50E56DEA
That is better but still have problem with the field now being a text field
format and have the length as 10 so if I have a figure like 53.32 it shows
as 52.3200000 10 characters or 1234.56 shows as 1234.56000 how do you trim
but still leave .00 at the end of a whole number
Regards,
Mark Howard
10 Willingdon st
Brisbane
Australia
Sent: Tuesday, 25 October 2005 8:41 PM
Subject: [SPAM++++] RE: [Vantage] Report builder help- try not to show 0 on
a report
Hi Mark,
to the calculation.
Shirley Graver
_____
Mark Howard
Please help!!
So far
IIF(TransAmt <= 0 , (TransAmt - TransAmt - TransAmt) , 0 ). The only way
with my knowledge to change the - amount to a positive number was to do the
above
want blank
Regards,
Mark Howard
10 Willingdon st
Brisbane
Australia
SPONSORED LINKS
Manufacturing
+w4=P
da+database+ng+s
Membership
turing+twar
Database
ring+are&
Pda
a+database+g+so
Database
turing+twar
ting+software
Database
uring+ware
_____
YAHOO! GROUPS LINKS
on the web.
_____
Yahoo! Groups Links
Scanned by ISheriff
You mean like using the character format option on the String function?
STRING(52.32,'>>.99') produces a string of "52.32". >> = blank when zero for left of decimal point. .99 is the right of decimal precision. If the field was previously used without formatting you might need to manually reduce the string character width in the Format... option on the field and also select Match Format.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Mark Howard
Sent: Tuesday, October 25, 2005 8:07 AM
Subject: RE: [Vantage] Report builder help- try not to show 0 on a report
Regards,
Mark Howard
10 Willingdon st
Brisbane
Australia
a report
Hi Mark,
to the calculation.
Shirley Graver
_____
Mark Howard
Please help!!
So far
above
want blank
Regards,
Mark Howard
10 Willingdon st
Brisbane
Australia
< http://groups.yahoo.com/group/vantage/files/>
SPONSORED LINKS
Manufacturing
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing> &k=Manufacturing+software&w1=Manufacturing
+w4=P
da+database+ng+s
Membership
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufac> &k=Membership+database+software&w1=Manufac
turing+twar
Database
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufactu> &k=Database+mortgage+software&w1=Manufactu
ring+are&
Pda
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+> &k=Pda+database+software&w1=Manufacturing+
a+database+g+so
Database
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufac> &k=Database+management+software&w1=Manufac
turing+twar
ting+software
Database
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufact> &k=Database+marketing+software&w1=Manufact
uring+ware
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage < http://groups.yahoo.com/group/vantage> "
on the web.
< http://docs.yahoo.com/info/terms/> .
_____
Yahoo! Groups Links
Scanned by ISheriff
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
To display as blank, use a character calculated field not a numeric.
IIF(TransAmt = 0,' ',STRING(TransAmt,"-$>>>,>>>,>>0.00")
Patrick Winter
Mark Howard
Sent: Monday, October 24, 2005 5:23 PM
Please help!!
So far
was to do the above
want blank
Regards,
Mark Howard
10 Willingdon st
Brisbane
Australia
------------------------ Yahoo! Groups Sponsor --------------------~--> Fair
play? Video games influencing politics. Click and talk back!
http://us.click.yahoo.com/T8sf5C/tzNLAA/TtwFAA/PhFolB/TM
Yahoo! Groups Links
Hello,
Linda
Please help!!
