If you are using report builder, join the part bin table
to the part table with a left outer join. If the onhand
qty is 0, you will get a question mark in the onhand field.
You can also format the field to show unknown values
as 0, instead of ? Hope this helps, if you have any other
questions, let me know.
Tim Care
Electro Chemical Finishing
Tim Care
----- Original Message -----
To: <vantage@egroups.com>
Sent: Wednesday, November 15, 2000 3:55 PM
Subject: [Vantage] Report Builder Help: 0 on hand qty records
> I am trying to work with a Usage report using the Part table joined to
> the PartBin Table. I can't get any 0 on hand qty records. I found the
> following in my Onelist archives (SEE BELLOW). This is from 9/22/00.
> Has anyone found an answer to this?
> Juliet Martin
> Rosenboom Machine & Tool, Inc.
> www.rosenboom.com
> We just worked with Vantage support concerning the issue of receiving 0
> onhand qty for another report and this was the response:
> Unfortunately, a part number has to have a least 1 in its quantity to be
> able to pull info for a report. Report cannot be run. Best way to
> simulate
...<snip....>.....
