Wayne,
Do you know if you can export payroll files this way. It would be very
useful for me if I could.
Rhonda
Sent: Wednesday, August 22, 2001 10:25 AM
To: lcyr@...; vantage@yahoogroups.com
Subject: [Vantage] Re: Report Builder Exporting
At 09:51 AM 8/22/2001 , you wrote:
generated a chuck of Progress source code in the Vntgwork directory to do
the work. Normally, it deletes it after it runs. But if you slowed down
the process (exporting to a floppy disk worked nicely) you could grab a
copy of the program while it was running.
Once you had that, you could make a permanent copy, and setup a menu item
for it. That way, users could run exports without having to grant access
to the whole export utility. You could also get fancy, and prompt for
dates or other parameters.
Unfortunately, in 4.0 they rewrote the export utility, and you can't do
this anymore. I messed around with NT permissions on VntgWork to deny
deletes and was able to capture all the temporary code. But it no longer
generates a stand alone program like 3 used to. The export programs that 3
generated will still run under 4; so if you still have a test DB with 3 you
can generate them there. Or I have some samples that you could use as a
skeleton to write your own. I'll try uploading one to our files section...
-Wayne Cox
Rhonda
>Yes, that would be nice to be able to export to excel dirrectly. I'm usingBack in 3.0 I discovered that when you ran the Export Utility, it actually
>4.0. What where your thoughts on exporting directly?
-Wayne Cox
