Hi - New to Epicor and am learning as I go. I followed the instructions from josecgomez on how to replace a grid with a baq custom grid. I’m getting the following compile error and am not sure what to do:
*Error: CS1061 - line 78 (2829) - 'Ice.Lib.Framework.BAQDataView' does not contain a definition for 'SuscribeToPublisher' and no extension method 'SuscribeToPublisher' accepting a first argument of type 'Ice.Lib.Framework.BAQDataView' could be found (are you missing a using directive or an assembly reference?)*
The original post is here: https://www.epiusers.help/t/efficiently-adding-column-to-datagrid/36283/25
Here’s my code, looks like I’m added to an already customized grid by the way:
// Custom code for ProjectEntryForm
// Created: 7/29/2021 4:45:45 PM
extern alias Erp_Contracts_BO_Project;
extern alias Erp_Contracts_BO_ProjPhaseSearch;
extern alias Erp_Contracts_BO_Company;
extern alias Erp_Contracts_BO_Warehse;
extern alias Erp_Contracts_BO_JobEntry;
extern alias Erp_Contracts_BO_JobAsmSearch;
extern alias Erp_Contracts_BO_JobMtlSearch;
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using System.Reflection;
using Ice.Lib.Broadcast;
public class Script
// ** Wizard Insert Location - Do Not Remove ‘Begin/End Wizard Added Module Level Variables’ Comments! **
private EpiDataView edvProject;
private Infragistics.Win.UltraWinToolbars.UltraToolbarsManager tools;
private Infragistics.Win.UltraWinToolbars.ButtonTool custButton;
BAQDataView baqviewpo; //addded 3/22
this.edvProject = ((EpiDataView)(this.oTrans.EpiDataViews["Project"]));
this.edvProject.EpiViewNotification += new EpiViewNotification(this.edvProject_EpiViewNotification);
object obj = typeof(Erp.UI.App.ProjectEntry.ProjectEntryForm).InvokeMember("baseToolbarsManager", BindingFlags.Instance | BindingFlags.GetField | BindingFlags.NonPublic, null, ProjectEntryForm, null);
tools = (Infragistics.Win.UltraWinToolbars.UltraToolbarsManager)obj;
custButton = addImportButton();
custButton.ToolClick += importClick;
public void CreateviewpoBAQView() //added 3/22
baqviewpo = new BAQDataView("ProjectPoCustom");
oTrans.Add ("ProjectPOBAQ", baqviewpo);
string pubBinding = "Project.ProjectID";
IPublisher pub = oTrans.GetPublisher(pubBinding);
if(pub==null)
oTrans.PublishColumnChange(pubBinding, "MyCustomPublish");
if(pub!=null)
baqviewpo.SuscribeToPublisher(pub.PublishName, "PORel.ProjectId");
this.edvProject.EpiViewNotification -= new EpiViewNotification(this.edvProject_EpiViewNotification);
this.edvProject = null;
// Begin Custom Code Disposal
// End Custom Code Disposal
public Infragistics.Win.UltraWinToolbars.ButtonTool addImportButton()
Infragistics.Win.UltraWinToolbars.ButtonTool custButton = new Infragistics.Win.UltraWinToolbars.ButtonTool("MassAddPOtoProject");
Infragistics.Win.UltraWinToolbars.PopupMenuTool pop = default(Infragistics.Win.UltraWinToolbars.PopupMenuTool);
custButton.SharedProps.Caption = "Mass Add PO To Project";
if (tools.Tools.Exists("MassAddPOtoProject") == false) {
tools.Tools.Add(custButton);
pop = (Infragistics.Win.UltraWinToolbars.PopupMenuTool)tools.Tools["ActionsMenu"];
pop.Tools.AddRange(new Infragistics.Win.UltraWinToolbars.ToolBase[] { custButton });
System.Drawing.Image intFuncImage = EpiUIImages.GetImage("InternalFunction");
Infragistics.Win.Appearance app = new Infragistics.Win.Appearance();
app.Image = intFuncImage;
tools.Tools["MassAddPOtoProject"].SharedProps.AppearancesLarge.Appearance = app;
tools.Tools["MassAddPOtoProject"].SharedProps.AppearancesSmall.Appearance = app;
return custButton;
private void importClick(object sender, Infragistics.Win.UltraWinToolbars.ToolClickEventArgs e)
try
if(edvProject.Row > -1)
LaunchFormOptions opts = new LaunchFormOptions();
opts.IsModal = true;
opts.ValueIn = edvProject.dataView[edvProject.Row]["ProjectID"].ToString() + "|" + edvProject.dataView[edvProject.Row]["Description"].ToString();
ProcessCaller.LaunchForm(oTrans, "UD40", opts);
oTrans.Refresh();
else
Exception ex = new Exception("Project is mandatory.");
ExceptionBox.Show(ex);
catch(Exception ex)
private void edvProject_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
// view.dataView[args.Row]["FieldName"]
// args.Row, args.Column, args.Sender, args.NotifyType
// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
if ((args.NotifyType == EpiTransaction.NotifyType.AddRow))
if ((args.Row > -1))
