I know this might be no-brainer but not able to figure out this problem. So we have a custom POForm ssrs report. Today when we did print preview for few Purchase order we find something weird happening at tax table.
Those 13 lines are for each PO line. That means there are 13 lines added in this PO and in tax table instead of showing one line it is showing for all. In-short, it depends on number of lines in PO. If there are 2 lines added in PO, it will show two line.
About amount to be 13% that is tax rate in Ontario, CA.
You might need to go to report builder and shorten the report (hover your mouse over the bottom and drag it up, or right click and open the Report Properties window to manually change the height).
Thank you though. This has been actually resolved. I had to make “consumewhitespace” property for sub-report as well as main report to true and it worked in my case.
Again, thank you for your time and help. Appreciated.
