Repaired Product to Stock reserved for Specific Customer
Hi All,
Here is a scenario.
We have a customer who we commit to keep on hand a manufactured product as a replacement if in case his unit fails. Therefore he has a problem, sends his unit in, we send one out straight away customer happy.
However, the unit he sent in, I would like to put back into stock (after repair and successful testing) but would like this unit to be specifically reserved for this customer until such time he has a another problem and we could send out this repaired unit.
And so the cycle would continue.
What is the best way to manage this? Once the unit has been repaired, how do I make it possible that only this specific unit can be allocated to this customer (and not run the risk this unit) would be sold to any one else?
Do you have Customer Supplied Inventory module? You could do that.
Hi Brett,
I would consider giving this a unique part number. It really isn’t the same as the original part since it is the customer’s and it has been repaired. That shouldn’t be called the same part number as newly mfd original in my opinion. Perhaps use the original part number along with a customer identifier. You could also add a customer cross reference part number that ties this repaired part number, and original part sold part number to what the customer calls it.
We use a “repair and upgrade” placeholder part number to track our part repairs. It is lacking however in that the part number does not provide details on what the part originally was. This would not be good for inventory of repaired parts. However we also use serial tracking and so the repair comes back with same serial number as original sold part number.
Nancy
I wonder if the new ‘track inventory by revision’ functionality in the Kinetic 2022 Fall Release would be useful. Receive the RMA’d part, assign it a different revision that’s not used for general sales, and use that for future repairs and re-orders.
2022 Fall Release - What’s New on ELC:
https://erpcustomer.epicor.com/lms/catalog/viewCourse?courseUid=4936
We use segregated BINs set up as Non Nettable to keep track of stuff like this.
Preventing it from getting used for customers we do not want to use it for is basically handled by physical organization (don’t pick from these BINs)
Using it for the specific customers we want to is done manually by a person. Having the stuff in BINs set up as non nettable makes it easy to put those BINs on a DB for a person to check when orders are getting filled. It is a lot of faff.
Hi John,
Thank you for this. How does this function work?
Define a new warehouse as a customer warehouse. When you add bins to it, you can set the customer who “owns” the bin. That way you can see what and who the parts are for.
