I need to remove everything after a character in the partnum. I know how to do this in Excel, but I need to do it in the BAQ. The trim doesn’t seem to work in the baq for what I am trying to do.
You could use a combination of left and charindex
Can you show me an example? Not used charindex.
the commands you want are the indexof function and the left command
try this:
//first setup some variables for demo purposes
string myPart = "abcd-1234";
string prefix= myPart; //in case there is no separator
string separator = "-";
int separatorLocation = myPart.IndexOf(separator);
if (separatorLocation >=0) {
prefix = myPart.Left(separatorLocation);
similar to what @timshuwy said… although I thought you needed it in a calculated field in a BAQ. For a calculated field in BAQ:
left(Part.PartNum, charindex('-', Part.PartNum))
The above would return the first X characters of PartNum where X is the position of the hyphen/dash character. If there is no hyphen/dash, it should return the entire partnumber. Replace the hyphen/dash with whatever character you’re looking for. Also replace the table you’re looking in if it’s not Part.
Oops… missed the “BAQ” requirement.
Are you sure that if the searched character isn’t found that it will return the whole searched in string?
LEFT("Hello World", charindex("-","Hello World"))
Wouldn’t the charindex("-","Hello World")
part return a 0, and the the end result would be an empty string?
Edit
A test of LEFT('Hello',0)
yields an empty string
Thank you! I was able to get it to work. My character was a “.” and the end result still sows the “.”. Is there a way to remove the “.”? If not, I can work with it, I was just curious.
charIndex('.',Part.PartNum)-1
Which will throw an erro if the searched item isn’t found. So try:
iif(charindex('.',Part.PartNum) < 2,Part.PartNum,Left(Part.PartNum, charindex('.',Part.PartNum)-1))
edit
correction of adding the -1
for stripping the search character.
I was mistaken. I was confusing the left function with the charindex.
I believe you’re right.
I never get tired of hearing that.
