Remove Duplicate from Results
This should be an easy one.
In a job, we have a list of JobAsmbl.PartNum.
I have created a BAQ that gives me the list if it contains ‘/Q’.
This has worked OK.
However, I need help to remove duplicate occurrences.
Here is what I get:
Q84951, Q91665, Q91665, Q91665, Q63427, Q85373, Q91665, Q91665
Here is what I need:
Q84951, Q91665, Q63427, Q85373
Here is an extract from the query phrase…
Your help would be much appreciated!
Himal
Use the Group By check boxes or, more simply, on the subquery tab use the drop down for “Distinct”.
Hi Jason,
Thanks for the suggestions.
This worked:
Cheers,
Himal
