Thanks mark!
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Sprowles, Mark
Sent: Thursday, December 02, 2010 12:20 PM
Subject: RE: [Vantage] Regular Cycle Counts vs. Yearly Inventory
We started cycle counting in 8.03 and it worked fine. We have since
moved to 9.04.506c and they have completely rewritten the cycle count
function. Many parts of the 9.04.506c cycle count function are bug
riddled to the point of uselessness, (mostly the report in ABC calc and
the blank tags. The report function within the calc doesn't work at all
and the system will not accept any count for a part that is assigned to
a blank tag, making the blank tags useless). Epicor says that these two
should be fixed in 507 which has been pushed out to 12/17... It is
useable, (with some custom band-aids), right now but if they get it
fixed it will be a very nice function.
Behalf Of Rob Bucek
Sent: Thursday, December 02, 2010 12:53 PM
To further this discussion, I'm curious for anyone doing cycle counting,
are they doing it using the cycle counting available in Vantage? If so,
what do you think about it? Is it efficient, effective, or buggy and
cumbersome?
Rob Bucek
FAX: (715)284-4084
<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf
Of Sprowles, Mark
Sent: Thursday, December 02, 2010 11:05 AM
We use a mix of value and usage to determine which parts are counted. We
much prefer cycle counting over a physical inventory. This way we have
small group of people that are very knowledgeable about our parts
counting regularly instead of a massive group of people that may or may
not know what each part even looks like doing a blitzkrieg count once a
year. We believe our accuracy rating is much higher for this reason. The
only problem we have is with Sarbanes Oxley audits. We are a publicly
traded company and thus under the ridiculous burden of Sarbanes Oxley.
The auditors have little to no experience with cycle counting and thus
it is a real fight to have them audit our inventory. If you too have to
worry about SOX then be very, very clear in your cycle count procedures;
especially where part categorization and count selection is concerned.
Hope that helps!
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ]
On
Behalf Of schmangy20000
Sent: Thursday, December 02, 2010 11:25 AM
Subject: [Vantage] Regular Cycle Counts vs. Yearly Inventory
This year we went from shutting down production for our yearly inventory
to regular cycle counts. There are several pros and cons to both
methods.
Doing a yearly inventory has an advantage in that, material handlers,
supervisors and other support staff are involved and can help locate and
move parts to count. In addition, production is halted, parts are no
longer moving through production and all staff are focussed on counting
as their priority.
Regular Cycle Counting allows greater flexibility for scheduling and
provides more time and care for tracking variances.
I'd like to hear your thoughts regarding these 2 methods of counting
inventory. I would also like to know if you count all your parts at
least once a year or just items that are over a certain cost etc.
Rob Bucek
FAX: (715)284-4084
Of Sprowles, Mark
Behalf Of Rob Bucek
cumbersome?
Rob Bucek
FAX: (715)284-4084
On Behalf
Of Sprowles, Mark
Hope that helps!
On
methods.
as their priority.
