I have created a dashboard that uses multiple queries to display all of the data I need. It uses the published value for the part number from the starting dashboard to fill the other queries. This works fine when the user enters or searches for a part using the tracker for the starting dashboard. However, our users want to be able to get to it from the context menu. It is putting the part number into the starting query for the dashboard but that part number isn’t getting sent to the rest of the queries. What do I need to do to get the part number to flow to all of the queries so all the data shows properly when it is selected from the context menu? I would hope that the solution would work when they change the part number on the form they are right-clicking in. I also would like to have the part number go into the field on the tracker but that isn’t as important as getting all of the data to show up.
Related Topics
Topic | Replies | Views | Activity | |
PartNum parameter not pulling into context menu dashboard | 4 | 612 | July 5, 2023 | |
Pass Right-Click Value to Custom Dashboard? | 11 | 4694 | May 15, 2019 | |
ERP 9 Dashboard filter | 3 | 529 | February 23, 2022 | |
Dashboard - Shared Tracker View | 10 | 1583 | February 4, 2021 | |
Part Tracker Dashboard Issue | 3 | 495 | June 4, 2021 |
