I am talking a closer look at trying to use the notify command, but am struggling to get it to work. According to the ICE documentation Notify takes parameters like you showed, but I'm not exactly sure how it works.
I am calling this from the orderhed_afterfieldchange method and want to have the order form update the edvOrderRel dataview, so I tried adding
edvOrderRel.Notify(new EpiNotifyArgs(Otrans,edvOrderRel.row,edvOrderRel.column)) but I don't think that is right. What should it be if I want the edvOrderRel to re-pull all the data in the edvOrderRel?
I specifically need to pull shortchar02 and the FirmRelease Boolean.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of John Driggers
Sent: Wednesday, September 26, 2012 10:34 AM
Subject: Re: [Vantage] Refreshing a specific EpiDataView
Are you notifying the dataview? That may fix it if you're not.
edv.Notify(new EpiNotifyArgs(oTrans, edv.Row, edv.Column));
*John Driggers*
*Chief Data Wrangler*
*I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
*:: 904.404.9233
:: waffqle@...
:: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
On Wed, Sep 26, 2012 at 1:16 PM, Tom J. Christie <tchristie@...
*John Driggers*
*:: 904.404.9233
:: waffqle@...
> wrote:[Non-text portions of this message have been removed]
> I am working on the Sales Order Form and have a situation where I use
> the after change method on shortchar02 (which is bound to a combobox)
> to change
> shortchar01 on all the releases associated with the table.
> I am able to change the orderrel table values just fine, but if I then
> tab over from the header tab to the release tab, the release doesn't
> show the change. If I refresh the whole order it will appear correctly.
> In the code, I could call Otrans.refresh after my code runs and it
> would update the OrderRel dataview with the new data, but
> OTrans.refresh has a huge overhead in the sales order form as it is reloading a ton of data.
> Is there a way to specifically tell the edvOrderRel that it needs to
> repull its data from the server? A targeted refresh of some kind?
> Thanks,
> Tom Christie
> Manufacturing Engineer
> AGM Container Controls
> 3526 E Ft. Lowell Road
> Tucson, AZ 85716
> PH: 520-881-2130
> FX: 520-881-4983
> www.AGMcontainer.com<http://www.agmcontainer.com/>
