References Dialog Speedup - Works -> (Need a ̶C̶l̶o̶u̶d̶ Guinea Pig) :dumpster_fire:
I need a Guinea Pig that is in cloud (on-prem works too) to test something for me.
When adding references, ie, in Functions, BPMs, etc, the list loads painfully slow.
Looking at it, it calls Ice.BO.BpMethod.GetPagedAvailableReferences,
with a page size of 5. It returns a json list of 5 references, for hundreds of calls.
I made a Preprocessing BPM on Ice.BO.BpMethod.GetPagedAvailableReferences
with only the content in custom code of: pageSize = 5000; to force it to return everything at once.
It’s blazing fast, even after client restart.
I’d like someone who hasn’t opened up a references panel today to do the same and share their
results.
Edit: Seems like it works well. I set it to a more conservative pagesize of 500 and it seems just as fast.`
Edit2: After some thoroughly unscientific testing after clearing the cache, I think the magic number is pageSize = 1000;
Edit3: Y’all can try other numbers, but 5000 is good.
Why you laughing @Olga? :exploding_head:
Or :popcorn:
I think after client restart you start over for sure, so you tested it
We’ll I’m assuming I did, but you know what they say…
I’m not privy to whatever kind of caching information is really on either end, so I
just wanted to confirm if the results are consistent.
I wonder how much memory and bandwidth it takes. If there is a problem with it…
I dunno, haven’t got that far.
5000 is probably not an appropriate number, but it sure isn’t 5 !
Maybe, i did not write it.
But
in-laws-im-watching-you
Yes, I’ve been told I know just enough to get me in trouble…
Sending a filter to the server would also be an improvement. Instead of sending all quickly, just return a subset. Just a thought. :thinking:
I’m not cloud, but I tried it on our upgrade test that I just created and it is MUCH faster than waiting for it to populate 1 by 1…
I’m going to experiment with page size.
I haven’t seen any issue with 5000, but it doesn’t mean I won’t.
I was hoping non-cloud would try as well, but I didn’t really know how fast on-prem
was loading in the first place. Nice to know it sucks there too :slight_smile:
It’s slow but not nearly as slow as cloud…
Hell now it loads in 1-2 seconds.
Down from 3 minutes.
Changed it to 500. Still just as fast.
I absolutely despise how slow it is, if this fixes it I’ll kiss you :kiss:
Pictures or it didn’t happen!
It doesn’t. This makes it much much worse.
Now he didn’t say where…
