Recurring GL entries
When closing period 11 they will create period 12 and name the group
RECUR-12. What ever period is being closed the next period recurring G/L
entries are created.
Jim Frice
> -----Original Message-----
> From: Joe Konecny [mailto:jkonecn@...]
> Sent: Wednesday, November 08, 2000 10:29 AM
> To: vantage@egroups.com
> Subject: Re: [Vantage] recurring GL entries
> They are... When you close (for period 11 11/01/00 - 11/30/00)
> should the group say RECUR-12 or RECUR-11?
> Jim Stetter wrote:
> > Joe,
> > Look at the G/L Journal Recurring Entries screen. Open the
> journal(s) in
> > question. You will see a Select Periods list of check boxes.
> Make sure the
> > boxes are checked for all the periods for which the recurring journal(s)
> > should run. Hope this helps.
> > Jim Stetter
> > Sent: Wednesday, November 08, 2000 9:24 AM
> > To: Vantage List
> > Subject: [Vantage] recurring GL entries
> > Does anyone have trouble with the recurring gl entries not
> > posting? For some reason it used to work but now they
> > don't post and we can't figure out why. Anyone know
> > of any gotchas with this?
You have to close the G/L month before the recurring entries will appear in
a G/L batch. Then, you simply post the batch. If that doesn't work, make
sure the recurring entry is active and that you have all of the fiscal
periods checked.
Randall Lunsford
Excel Machinery, Ltd.
e-mail: rlunsf@...
Phone: (806) 335-4565 ext. 531
Fax: (806) 335-9017
Sent: Wednesday, November 08, 2000 8:24 AM
To: Vantage List
Joe,
Look at the G/L Journal Recurring Entries screen. Open the journal(s) in
question. You will see a Select Periods list of check boxes. Make sure the
Jim Stetter
To: Vantage List
eGroups Sponsor
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
Jim Stetter wrote:
> Joe,
> Jim Stetter
> To: Vantage List
> eGroups Sponsor
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
Recur-12
Deb
Reeder & Kline Machine Co.
Sent: Wednesday, November 08, 2000 11:29 AM
Jim Stetter wrote:
> Joe,
the
> Jim Stetter
