Can someone point me to any documentation that outlines recommended database maintenance to be done on the EpicorLive10 DB per-emptivly?
The database size is increasing substantially and I do not want to get to a point that users are complaining about the system access time increasing and have an unhealthy database.
I assume that the database is in FULL not SIMPLE mode. If you backup the SQL log files regularly (depends on your business), you should be able to stabilize the growth. For our DB, we perform a full backup nightly and the logs are backed up hourly.
